hosed up headlight mod
did the headlight mod with 2 relays, cut all three wires at the headlight, new wires installed from headlight (12 ga) to the relays one for high beam one for low and grounded directly to battery. have a fused hot wire directly from battery to relay for hot and both relays are grounded on the fender at the same place, i use my hi-lo switch to control whichever beam i need. my hi beams are great, low beams sux as bad as before almost yellow. if i unhook one of my low beam wires at the relay i have a bright light and 12.3 volts at the light, hook both low beams up and only get 5.90 and have yellowish lights and when i unhook either low beam at the relay, i have feed back to the opposite low beam headlight very dim but its there. with all new wires everyplace is it possible i have a bad headlight socket or do i have a bad ground. sorry for the long post
If your reading half your normal voltage with both connected your wired wrong is all, if the voltage is cut in half your running parallel, if the amperage is cut in half your running series.
have you ever thought about these. http://www.puredieselpower.com/catal...ack-p-271.html
i bought some and they work great.
Hey, Gunnie. If you can sketch how you hooked everything up and send it to me, I'll take a look at it and figure out what is wrong. If you wired them in series, they will both be the same brightness (dim) and if you unhook one, they will both go out. I doubt that is the problem. Sketch it out in MS paint or some other software or scan in a pencil drawing and sent it to me if you can. We can figure it out. Sounds like you have a relay coil or something pulling down the other light. Make sure your relays are hooked up right. Those stupid little diagrams that are embossed in the top of them are worthless and hard to read if you aren't familiar.
I agree with Lance, it sounds like you've got them running in series somehow. Relays really aren't my bag though so I couldn't tell you what's wrong there. Post up a schematic if you can and there's plenty of smart folks on here that can check it over for you!
Ditto that. Parrallel would be the same voltage on each lamp, series would read 6V or so across each.
Remember, headlights really aren't wired in these trucks as simple as a hot and a ground. They have to use the headlights switch, the multi-function switch (turn-signal flipper) and the ECM and all kinds of other bs to make them work. Did you cut the headlight wires clear of ALL facory wiring? Sound like you are dividing the voltage between the lamps and some other device in the truck. I'm sure when you finally read these posts you will be saying to yourself, HUH? These folks are confusing the crap out of me!!!
Let us know. We're here to help.
EDIT: Guess everyone else beat me to it. See what I get for not reading the entire thread
well this is great , all the replys from you guys, now i'm gonna get my butt kicked for this thread cause of where i got the schematic. let the flames begin.
i hope i can post this without making the mods mad
thanks for your help guys
http://www.ford-trucks.com/article/i...r_Brights.html
I'd try to get a hold of the actual wiring diagram for your truck model and compare it to the schematic you wired up. See if everything looks correct.
FWIW - someone correct me if i am wrong
you should pull the input voltage off the alternator output.
the alternator outputs 14.4 regulated. that is the "high" voltage you want to see at the bulbs.
i "think" most modern alternators sense this voltage at the terminal on the back of their case.
so it makes 14.4 there.
and whatever you get at the battery terminal due to corrosion, poor connections, poor crimping, low quality wire, cable length, insufficient gauge is probably less.
so you want the 14.4 from the alternator, from the source
the battery is self regulating to ~12 volts
