Holley Blue pump question
I'm going to be installing a vulcan relocation kit and a draw straw II on my truck this spring to replace the intank unit dodge put on when they recently replaced my vp44. I was think of going with a Holley Blue pump for my set up. I've seen that alot of people on DTR run this pump or the holley black. I'm not going with a FASS because it's not in the budget I have for a fuel system. Any of you that run the Holley pump, do you run a filter before the pump? If so what is it? Also I saw on Jegs and Summit Racings websites that there isa Holley Blue and a Holley Blue Marine pump. Besides the price what is the differance between the two?
take a look at my pics for secondary fuel filter ideas but my hbp died a week after i installed the filter go to autozone about 30 to 50 dollars cheaper the differance between the marine and the black is the gph go with the holley blue 14 psi and 110 gph you may need to strech the spring to get your fuel pressure up to 14psi
I put a holley blue in dad's truck, he has an in-tank, and they work great together.(18psi -15psi) Why do you want to put a draw straw in it? The blue is more likely to fail than the in-tank. IMO
I had a Hollye Blue on truck I just sold ('99 3500).
It was installed just in front of tank, no filters, no valve, etc. I had approx 60,000 miles on it and never had a problem, I carried a spare in the truck, just in case but it worked great for me, I had same "budget" problems and I didn't want to "shell out" $ 600.00 for a FASS.
It's a very easy installation, I even used same wiring as OEM pump and never had a problem, it's a little noisy when you run it with motor shut off, but once truck is running you won't hear it.
Heck I still have the spare here, if you want it let me know $ 50.00 shipped.
I have a 12v now and don't need it anymore....
Thanks for all the replies, I'll go with a holley blue.
Valv, you have a PM.
From what I understand if you have too much pressure it'll cause hard starts and after a certian PSI the fuel gets sent back to the tank.
on a STOCK truck fuel goes back to the tank.
its what cools the vp. The more volume the better. Now with the intank and holley blue you'll only see 20-22 at idle. and you dont start seeing hard starts till 30+psi. So no worries
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
RockRover
Apr 2, 2005 08:48 PM
