Holley Blue Benifits
Old Aug 8, 2006 | 04:53 PM
sjwhitaker's Avatar
Hey guys, what are the benifits of the holley blue other than increase in fuel pressure? Will this pump increase HP or TQ numbers over the stock truck? Is it hard on the VP 44? Does it actually flow more fuel into the engine? or just the pump thanks for your time and help on this subject.
2001 CTD HO Automatic Juiced with K&N, muffler and silecer m.i.a
Old Aug 8, 2006 | 07:23 PM
blackdiesel's Avatar
Registered
it wont give you more hp. No pusher pump will give you more power. it will give you more pressure and thats all you can ask of it. More psi is crutial for pro-longing your vp life.
Old Aug 8, 2006 | 09:16 PM
Tiny's Avatar
The Holley blue will not add power, but it will allow enough fuel that other mods can add power. Before the pusher I could pull fuel pressure down to 4psi, now I cannot pull it below 16psi. So it feeds enough fuel to make the most hp possible.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
boughtadodge
Jan 21, 2003 10:03 AM
Joe V
Jan 16, 2003 09:37 PM
