High Flow Delivery Valves
Will theses delervy valves work good with my setup? I have a 94 with a 0 plate and a governer spring kit, but still have stock injectors and dont really want to upgrade them because i want to truck to be wheelable. My brother has the same setup but with a 98 so he has 191 delivery valves and his truck is way faster. will these flow to much fuel for my setup or will my injectors limit it them and it should perform good? And if not were can i pick up some 191? Link below to valves. thanks
http://www.citydiesel.net/high-flow-...ta97usnde20fa4
Yes, I think they would help you out. I put some 181's in mine, and it helped it a little. 191's should be even more of a kick in the butt. Id say go for it, but watch your EGT's.
Eric
Eric
Our delivery valves will give you approx. enough fuel for an additional 60-65hp with your setup. With larger injectors it will be even more. Adding larger delivery valves (any good brand or size) will make it fuel a lot harder sooner
-Jason
-Jason
