HELP!!! Where is the MAP Sensor/Boost Sensor
Old Jan 1, 2006 | 12:38 PM
Booost Almighty's Avatar
I bought a Power Edge Comp fuel box and I am trying to install it. I can not find the MAP SENSOR/BOOST SENSOR. It says disconnect the stock wiring harness at the boost sensor located to the rear of the fuel filter housing near the top of and on the engine block.
Can someone make this a lil' more clear. I cant find the thing no where. I have a 98.5 model.
Thanks in Advance
Old Jan 1, 2006 | 01:00 PM
99NVRam2500's Avatar
I just did the same thing a couple of days ago, it is above the lift pump and aft of the fuel filter. The pics from EDGE make it look under the fuel filter to me, but I finally found it.
Old Jan 1, 2006 | 01:02 PM
Its on the driver side correct?
Is it easy to see if you are looking at the correct thing or is it kinda Hidden. HA? This is driving me crazy
Old Jan 1, 2006 | 01:09 PM
mishkaya's Avatar
Yes it is on the driver's side, and no it's not that obvious to see even when you're looking straight at it unless you know what you're looking for. I found it by feel, after I got tired of looking for it.
Good luck.
Mishkaya
Old Jan 1, 2006 | 01:41 PM
fschiola's Avatar
Maybe this will be of some help.
Cilck
scottboy69358
Jul 4, 2013 02:05 AM
Redlinear
Feb 14, 2013 01:10 PM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
