Help! Smarty Doesn't Work Anymore
So far its good. Need some more tuning and what not. Still need to get the solenoid in there to kill the truck, and there is a hunting issue when I shift gears. I'm not sure if thats related to the 4kgsk or if its not setup properly. I'm just happy I no longer have to worry about electronics with this truck. Oh, and no CEL!
did you have the injectors pop off pressures set when you did the conversion. cause the vp44 and the p-pump have different pop off pressures . this could be part of that hunting issue you are having if you didnt get them reset. good look with your tuning
by the way it looks really good.did you buy a conversion kit or did you just buy the parts needed seperate
When I shift into third (or in and out of the throttle at all) it will jerk ahead, then slow, back and forth. At first I thought it was my foot slipping, but now I'm not so sure. I'm wondering if the GSK needs adjustment. But this is the first p-pump I've mucked with, so I'm still on a learning curve.
seabee, injectors haven't been touched in 2 years. It had a bit of a lope after my drive, but I believe that is due to a low idle (700). I'm gonna bump that up in the morning, as well as give it an oil change. I got the kit from Schied's, and then pieced together the rest.
I got to lay off the beer
I remember it would do it so violently at WOT the tires would chirp but it went away after the 10kazillion adjustments I've made. Piers told me once what caused it but for the life of me I cant remember?
WOT is nice and smooth, its just low rpm where it happens. Speaking of WOT, I need more of it. Only get 31psi out of the turbo. Had 43 with the VP. Time to slide the plate forward.
Planning on both. I've got the stock plate thats gonna become a 100 eventually, and I'll bump the timing once I've got some more miles on it and have most of the issues out of the way. Still on stock gasket and head bolts, so not sure how far I'm gonna go with the timing.
16° should be a good start without comprimising the HG.. Up the idle to near 850 and it should take care of some of the low end lope. The low idle speed will cause the rack to pull back to near full off and try to kill the engine. You would be amazed how much idle speed setting affects it. I had trouble after getting the timing done with shifting to 3rd etc and finally bumped the idle up to 855 with A/C on and it sure smartened up..
I gotta see that thing!!
Probably safe to say I'm the only one on the sight running both. Should I see if I can cram a dual CP3 in there too?
Jason, I'm gonna bump the idle up after do the oil change, and I'll probably slide the plate forward. I actually stalled the truck taking off in second. I'm gonna blame it on the low idle. The exhaust seems to have a little different sound too. Hard to explain. I'll give you a call when I'm coming home on my weekend off, meet up in Red Deer or something.
