Help...Intercooler flow rate?
Old Nov 13, 2007 | 02:43 PM
LYNCHMOB's Avatar
Can anyone help? What is the minimum to maximum intercooler flow rate for a stock '98 cummins diesel? What size requirements are needed for an intercooler? I'm in the process of putting a cummins into my '82 cherokee 4x4, and I need to retrofit an intercooler into my core support. The smaller the better, but I don't want to reduce my ability to upgrade horsepower in the future. Any suggestions? PLEASE HELP.
Thanks,
Ryan
Old Nov 15, 2007 | 02:31 PM
NoSeeUm's Avatar
How much boost do you intend to make and what RPM do you need to run at?
Some numbers @ 3000 RPM and Sea Level:
Boost CFM
5 423
10 519
15 612
20 704
25 794
30 882
Lbs/Min = CFM / 13.35
It is mostly about pressure drop I would think. Find one that will flow what you need and has an acceptable pressure drop at that flow rate.
Jim
YounanDiesel
Oct 27, 2011 09:00 PM
Canadian24v
Nov 8, 2008 12:06 AM
Lrdchaos
Sep 5, 2005 03:36 PM
jethroish
16
Jan 18, 2005 04:00 PM
tony
Jan 8, 2005 06:10 PM
