Head Work?!?!
Old Jul 14, 2007 | 04:53 PM
JSCumms2000's Avatar
Head Work?!?!
How much would head work cost me to get done... a rough estimate, of course... port and polish for sure, i know head studs are 4 or 5 hundred what else??
Old Jul 14, 2007 | 06:31 PM
clutch1's Avatar
around $340 for o-rings or firerings depending on the shop. not sure on the P&P
Old Jul 14, 2007 | 07:52 PM
thekidfan's Avatar
Depends how far you'd like to go.....price up to about $6,000
Old Jul 14, 2007 | 08:12 PM
wow... well for my application what should i look into doing??? i'm going to twins (s400 on bottom) along with nitrous, mach 6's...
Old Jul 14, 2007 | 08:32 PM
clutch1's Avatar
all the bells and whistles, you might be wanting to be hitting 65-70psi to get the full effect of the twins.
Old Jul 15, 2007 | 07:15 AM
Dshiftff's Avatar
get in touch with andy sebek over at keystone diesel. he has a guy pretty close to you that does what your looking for.
Old Jul 15, 2007 | 03:56 PM
Thanks alot guys.. appriciate it!
Old Jul 15, 2007 | 04:00 PM
Jetpilot's Avatar
There are lots of options..... Normally a 24v head should be checked for cracks and pressure tested. If good I would go ahead and rebuild the head, valve job, new seals, guides etc. You will need to have the head cleaned, decked, and either o-ringed or fire ringed. You could also add some upgraded valve springs. As for the porting a basic good port job runs around $800 but a full blown job can runs several times that amount.
Doug
Old Jul 15, 2007 | 06:25 PM
99globalwarmer's Avatar
i have a fully built head and a zz fab intake, larger valves, intake porting, exhaust porting, new seals, guides, seats it was pressure checked decked, and was fire ringed. the hole job including the 1000 dollar intake manifold with 3 nitrous spray bars, water/meth ports was a little over 3500.00
Old Jul 15, 2007 | 06:49 PM
bnold's Avatar
Mine was over 3k by the time I replaced valve guides, added F1 springs, new seals, new valve cut, mag flux test, deck, o-ring and new slightly modified marine gasket
Old Jul 15, 2007 | 08:07 PM
Jetpilot's Avatar
99globalwarmer,
Who did your head?
Old Jul 15, 2007 | 09:23 PM
bnold's Avatar
Ya that was crazy cheap!
Old Jul 15, 2007 | 09:25 PM
bnold's Avatar
Here is some ifo I dug up when getting mine done:
piers
$300 oring
stage 1 port $1295
stage 2 port $1495
Mike's Custom Truck Builders
$300 oring
$70 resurface
$70 new style guides
4200 gasket set
.041 or .051 ring size
Zach hamilton diesel service.
$300 O-ring
$50 Deck
Ray Little
817-477-0682
decking & oring 475.
stock widest ring gasket $120
.043
Disassemble Vac and Mag crack check $125
Assembly $150
new seals $42 Viton material
Tracy extreme diesel
336-961-2884
$700 fire ring
power by poole
may do exchange
calling back morning
oring- $400 resurfacing, cutting, orings
headgasket $110
F1- $650 nothing to install
Old Jul 15, 2007 | 09:29 PM
a local shop he also did inlinesix's head he is actually a good friend. he is a really nice guy the name of the shop is BROWNS DIE
Old Jul 15, 2007 | 09:30 PM
a local shop he also did inlinesix's head he is actually a good friend. he is a really nice guy the name of the shop is BROWNS DIESEL.
