Head Studs
Old Aug 14, 2006 | 01:41 AM
Teddy Bear's Avatar
Head Studs
If i buy a set of studs for my truck could i go ahead and get them installed one at a time without removing the head from the truck? Is there anything wrong with this? Just figured it might help my HG hold on a bit longer when i decide to go to a bigger charger.
Old Aug 14, 2006 | 01:59 AM
PourinDiesel's Avatar
Yeah you could do that.
But I recommend bottom tapping the block holes if you want to do it right.
Old Aug 14, 2006 | 02:28 AM
Teddy Bear's Avatar
What exactly does that mean?
Old Aug 14, 2006 | 03:06 AM
Most of the head bolt engine block holes are not tapped completely resulting in a stud's threads not fully engaged to the engine block. This also causes the stud to protrude and can cause some clearance issues with other engine parts like valve covers etc.
Another thing that is a potential when the stud is not fully depressed is the pulling of block threads. Although this is rare, your potential for this happening increases if the stud is not threaded in completely into the block.
Old Aug 14, 2006 | 06:53 AM
Dshiftff's Avatar
if you go with arp's you will now have to get your rocker pedistals machined. they supply a shorter tower bolt so you dont have clearance issues anymore.
Just did mine and came out nice with no valve cover grinding.
Old Aug 14, 2006 | 08:02 AM
one54ton's Avatar
I kept my head on. It was an S.O.B. but it works great.
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
