Head stud torque
Old Apr 13, 2010 | 07:04 PM
kyle_truck_pull's Avatar
Head stud torque
What's the ideal torque for arp head studs? And how many steps when torqing them? Thanks
Old Apr 14, 2010 | 12:22 AM
Tate's Avatar
125 is the reccomended torque. I took mine to 100 ft-lbs, then increased in 5 ft-lbs increments until 125, then torqued it three times at that spec. Back off the nut before torqueing. Retorqued after running it to temp and cool, then drove it a couple days and retorqued. Been bagging on it since with good results.
Old Apr 14, 2010 | 08:41 AM
sheriffav8r's Avatar
Is it necessary to recheck the torque on the ARP studs?
Old Apr 14, 2010 | 12:32 PM
Tate's Avatar
Gaskets will start to settle and will reduce the stretch on the stud. It might not be as critical on a standard headgasket, but its a good idea with o-rings.
Old Apr 14, 2010 | 08:25 PM
I just have the standard OEM head gasket with the ARP studs torqued to 125. Just wondering if I need to pull the cover and valve train to check the torque values....
Old Apr 14, 2010 | 10:17 PM
Tate's Avatar
Be pretty hard to check them all without pulling the valve cover or train.
Old Apr 16, 2010 | 01:32 PM
Let me restate that: I don't want to pull the valve cover and rockers off unless I have to recheck the torques....
Old Apr 16, 2010 | 04:46 PM
Tate's Avatar
Depends how confident you are that they are tight enough. A couple hours could prevent a gasket blow out, and give you peace of mind. But in the end, its your call.
lostcreek21
Mar 1, 2010 06:13 PM
hic316
38
Jan 12, 2008 10:03 PM
francis212
Sep 5, 2007 10:02 PM
74dart
Jul 7, 2007 07:58 PM
dodgediesel
21
Aug 13, 2006 10:20 PM
