Head gasket?
Old Nov 20, 2005 | 04:37 PM
vetteair's Avatar
Head gasket?
Am planning turbo and pump mods on my 95 160hp auto, to hopefully get 350+ hp. Would it be good peace of mind to "O" ring the head, or would it be a waste of time at this level? My useage will be heavy towing.
Old Nov 20, 2005 | 08:07 PM
mr T's Avatar
u dont need to do anything except install some gauges...get a 100plate and some gov springs and u'll be hovering at the 300hp mark already
Old Nov 20, 2005 | 08:21 PM
vetteair's Avatar
Would that be with the stock turbo or with a after market turbo? If its with the stock turbo will EGTs be an issue?
Old Nov 20, 2005 | 08:50 PM
1320's Avatar
with any heavy towing you need gauges. trans temp, egt, water temp (I like), boost is always fun to look at.
Bypass the wastegate, on the stock turbo, a plate, gov springs, valve springs for an exhuast brake , and maybe injectors at some point.
No need for oringing the head.
If egt are a problem get a water/meth kit and run straight water when towing with a small jet, it will suck the heat right out.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
