hamilton cam first impression
Old Feb 17, 2010 | 11:42 PM
DodgenIt's Avatar
Originally Posted by RowJ
Mild after market cam can do wonders for better engine breathing on low end.
RJ
What kinda cam would be considered 'mild'?
I had read in the past that there really isnt a towing/mild cam.
That they are more for hittin that bigger power mark.
Old Feb 18, 2010 | 04:34 PM
Big Deezul's Avatar
Any drop in cam would be concidered mild. With a drop in cam, you wont see a huge power increase on the dyno..maybe 35-40hp, but what you will get is lower egts, quicker spool up, and a broader powerband since you will start making more power sooner.
Old Feb 18, 2010 | 06:29 PM
Tingram's Avatar
from what i have drove mine so far a little over 400 miles, and from my calculations i have dropped 4mpg after changing to this cam, i am going to run one more tank of fuel through it and run the numbers again then let you guy know
Old Feb 18, 2010 | 07:52 PM
DodgenIt's Avatar
Tingram, dropped as in went from 20 mpg to 16 mpg???
So what are some examples of a drop in?
Whats differant about a drop in cam then something else?
(Im vey new to cam discussion)
TIA
Ian
Old Feb 18, 2010 | 08:16 PM
Big Deezul's Avatar
anything larger then a drop in can will require modified pistons among other things.
Old Feb 18, 2010 | 10:54 PM
Mike Holmen's Avatar
The Guru
I picked up abit of mileage with my camshaft install. Sounds odd. You make sure that the marks line up on the gears? If you go for the fly cut piston camshaft, you should also do lots of porting on the head. These ctd head don't flow air very well. Try another tank and see what happens.
Old Feb 19, 2010 | 03:34 PM
DodgenIt's Avatar
So what cams out there are drop in?
I wouldnt mind puttin one in when compounds happen for me and am lookin for advice.
Old Feb 19, 2010 | 04:00 PM
Big Deezul's Avatar
hamilton big stick is drop in
Old Feb 19, 2010 | 05:22 PM
Tate's Avatar
Just about any cam out there is a drop in. Anything that requires piston cutting would likely be labeled as a competiton cam and have a disclaimer about needing such. It used to be billet cams needed cam bearings installed in the block, but both Hamilton/Colt and F1 have billets that can be used without bearings.
Old Feb 19, 2010 | 10:23 PM
The Guru
Can you get the big stick with a bolt on cam gear? Any update Zach on the new stick? I might be thinking about trying in new truck that I'm building up?
Old Feb 19, 2010 | 10:55 PM
DodgenIt's Avatar
Any links out there?
I tried looking up Hamilton Cams and all I could get was a contact us page. No product.
And I can find very little about other cams on differant diesel sales sites.
Old Feb 19, 2010 | 11:07 PM
The Guru
Try Peak Diesel?
http://www.peakdieselperformance.com/home.html
They have info on the cams. Thats where I'm going thru for my cam/gear/springs for mine.
Old Feb 20, 2010 | 07:46 AM
Big Deezul's Avatar
yes you can
Old Feb 20, 2010 | 07:32 PM
The Guru
How deep is the bolt drilled? Any issues with the cam gear walking off the camshaft, for a big pump high rpm engine?
Old Feb 22, 2010 | 06:44 AM
Tingram's Avatar
ya iam sure the timing is right on, the truck runs great and does fine i just dont know why it is using more fuel i would have thought for sure it would have used less fuel. maybee it is just trying to tell me it needs a bigger turbo so it can move more efficent air!!!!!!!!!!!!!
