gsk
Old Feb 1, 2007 | 04:28 PM
Harold Swanson's Avatar
gsk
what happens if you do not get the adj. nuts the depth as they were?
Old Feb 1, 2007 | 06:37 PM
clutch1's Avatar
probably a slugish responding throttle or maybe some hunting, almost the same as worn springs
Old Feb 1, 2007 | 07:53 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
It depends on which way you get them off, too loose will cause a low idle, sluggish throttle and limited RPM's. Too tight will give the affect of performance GSK's but with hard starting and high idle, and you may possibly have to step on the gas to get it too start.
Old Feb 2, 2007 | 10:36 PM
Fueling around's Avatar
Most of the time it may not be very evident. Sometimes a throttle surge or flutter is very noticable. Optimal GSK setting may be looser or tighter than stock settings.
What drives your question?
Old Feb 3, 2007 | 06:16 AM
Txwelder's Avatar
I installed mine to the exact depth as stock and the truck wouldnt start. I just kept tightening them until the truck started and idled properly.
Old Feb 3, 2007 | 08:24 AM
berner's Avatar
I installed mine to the stock depth and had no problems at all. I was a bit concerned at first as the springs are actually a little loose with the truck not running. I've had them in for over 4 years. It fuels hard to 3200RPM. Haven't taken it higher due to stock valve springs.
siebertl
Jun 10, 2007 02:29 PM
SHARPMACHINE
Mar 6, 2007 08:45 AM
plow
Aug 9, 2005 04:25 PM
MR HYDROSEED
Mar 9, 2005 10:49 PM
Got Smoke?
Oct 26, 2004 03:57 PM
