Gonna Hook Up The Wire!
Old Sep 5, 2003 | 11:39 AM
Mule Skinner's Avatar
I have decided to hook up the comp wire. Looking for suggestions on settings when pulling heavy loads, I have seen where guys only go so high with settings, I assume to keep from leaving "dodgeware" on the road. Have been running w/out wire and been happy but the bug is growing. Still stock clutch-- I know -- I need to be careful
Old Sep 5, 2003 | 12:51 PM
TPilaske's Avatar
Re:Gonna Hook Up The Wire!
I always ran at 5x5.... I dropped it down to 3x5... and now i'm running on 3x2. I usually don't change it whether i'm just driving or towing... Just play with the settings, you'll find one you like... ;D
Tony
Old Sep 5, 2003 | 01:37 PM
geer's Avatar
I run mine on 5x5 all the time. My trailer and sleds weighs about 7000 lbs.
Old Sep 5, 2003 | 02:58 PM
smittybuilt's Avatar
go for it!!!! ;D ;D my stock clutch slipped from day one when i hooked the wire up. it will only cause you to start and save for a clutch. happy times are ahead
Old Sep 7, 2003 | 09:28 AM
Racer57's Avatar
I run mine on 1x1. I do this when towing 10K 5ver and also running down the freeway. I know, 1x1 is a defueling mode at low boost, but I believe it increases miles per gallown. When the boost and RPM's come up while towing then it's about the same as running on 1x5. But then again, I have injectors and unless I missed it in your signature I don't see that you do. ETH's don't respond as well to fueling boxes as do ETC's. Put a set of DD2's in and you will be smiling all the way to the bank to withdraw money for your clutch upgrade.
kerry.king
Mar 14, 2011 10:32 AM
rjm022
May 1, 2007 05:15 AM
matthopp
May 11, 2004 04:38 PM
TPilaske
16
Nov 22, 2002 08:15 PM
admin
27
Nov 12, 2002 04:47 PM
