Going bigger sticks, M4's or DDP 150's?
I know you spend some time in the hills of WV too. I go up 522 out of Hardy county up the 9% grade every now and then. Empty egts pulling the hill at 70 mph in 5th gear are usually 900-1100, but they can creep up to the 1300 range if I'm really booking.
Yeah, lots of time in those hills. I'm leaving now for Metz, W.V.
If you are looking for some bigger injectors to sledpull, I have a set of Buddha Power 8 x .011's. Bought them used and never tried them. I would guess thay are big for a little turbo like you are running.
I have run DDP's 1's, 2's, 150's, and 250's. F1's 1.2's, 4's, 6's, and 7's. I only compare what I have run.
I say call scheids and get a set of bigguns. Ive got a couple and love them but i dont have them in tow vehicles. 200s are streetable but no way towable, the 250+ are great when your towin the sled.
From what I understand, the 4's are suppose to be too much for my turbo & towing. From the dyno numbers I've seen, they seem to be the same as my Dragons I'm running now.
I am just mad about losing to that guy. I usually stomp him. I know my truck is having issues, but I'm gonna get those issues fixed & then decide. My setup is perfect for everything I've thrown at it, but it seems like everyone is stepping up in power except me. Maybe the extra revs will make all the difference once I get this code thing fixed. Thanks for making me think.
JLent, there is always gonna be someone bigger, faster, stronger. Don't get too caught up keeping up with the Jones, wait till he goes broke and then you only have to show up to beat him. From what I've read on sled pulling, once you get in that 600 HP range, you break every other pull till everything is upgraded in the drive train. I suspect you're on the verge of losing axles, pinons and drive shafts as you sit. Might want to work on making 100% use of your current power so you can keep your daily work truck on the road.
I'm like the rest of everyone on here, it's too fun to play but we all gotta draw lines somewhere. Then again Mach 4's aren't that big a of step up. Maybe they'll tow great and give you that extra 10 feet.
By the way, I'm not a guy who gotta win, believe me. Its just bothering me because I talk to this guy at every pull & he is a truck driver who works with my friend. I'll never hear the end of it. Besides that, he put $4000 into the Monster pump, injectors etc. Its just friendly rivalry.
M4s would be okay towing with your turbo, I don't tow as heavy as you but I run a HX-40 and egts are not a problem. I agree that 4s wouldn't be much power difference from what you currently have, if any at all.
