Glacier Kit Install Time?
Old Nov 26, 2006 | 11:07 AM
Dexter Bob's Avatar
I will be purchasing a Glacier kit in the VERY near future and was wondering what the typical install time was? How about difficulty on a 1-10 scale? My 99 2500 has only 45K on it but I don't want to be stranded on some mountain road in the boonies! My FP gauge is in the mail as well!!
Old Nov 26, 2006 | 11:14 AM
pind's Avatar
The toughest part of installing the Glacier kit used to be the dorman connector on the tank sending unit. As I understand it, this has been replaced by just chopping into the existing siphon line from the tank, so it should cut the time down substantially.
It will still take a little bit of time, depending where you decide to mount the pump, but even if you are 75% thumbs, probably a couple hours at most. It took me more than that but I am extremely picky about how things go together.
Side note, watch the JIC fittings on the regulator, the T and the filter adaptor. Make sure these are perfectly clean when you put them together, and do not overtorque them. Also, make sure to use the pre-filter FF5079 I believe. It is an inline filter that looks much like a 3/8 gas filter. BUT, it isn't, it is just a screen within a casing. This can save your pump from picking up debris from the tank.
Good luck with it, let me know how it goes.
Old Nov 26, 2006 | 09:57 PM
TNfarmboy's Avatar
I also put in a ball valve so I don't get drenched by diesel when I change the inline filter. To me it was deciding where to mount things so I could have good access later.
Old Nov 26, 2006 | 11:11 PM
Dexter Bob's Avatar
Sounds like a good idea. How often do you change that inline filter? For your ball valve did you just use a standard water valve with brass hose barbs and hose clamps??
ptgarcia
Aug 18, 2006 03:52 PM
team
Jul 4, 2006 11:39 AM
srt20
13
Jun 17, 2006 01:19 PM
Raspy
36
May 23, 2006 10:28 AM
