Getting it dialed in! New Sled Pull Videos
Old Jun 29, 2007 | 09:55 PM
kas83's Avatar
Keep it up, good job. Unlock the converter at 3500 to avoid falling under the charger? How big is that thing? Truck looks really nice, clean.
Old Jun 30, 2007 | 10:42 PM
Bobcat698's Avatar
Here is a hook in Jefferson WI:
Click here to see Video
I need more fuel!
Old Jun 30, 2007 | 10:43 PM
Bobcat698's Avatar
East Troy, WI
Old Jul 1, 2007 | 10:59 AM
TxDiesel007's Avatar
Good to see u back pullin again!
can u still daily drive that thing? Seems to me its morphin more and more into a pullin truck and is leaving teh streetability behind...
Rick
Old Jul 1, 2007 | 11:58 AM
getblown5.9's Avatar
Originally Posted by Bobcat698
was that a sled pull or a rock crawling competition...my goodness that track was rough. they should have had tough truck competition on it, not a sled pull.
Old Jul 5, 2007 | 09:42 AM
Bobcat698's Avatar
Harrisville WI
I like the new single stack look!
Old Jul 5, 2007 | 09:48 AM
Muddin_dude06's Avatar
Good hooks Garrett! Glad to see you got the spoolup issue fixed, and ALRIGHT single stacks are the way to go!
Old Jul 5, 2007 | 11:41 AM
Paul Winey's Avatar
Great pull at Harrisburg - that was without your front weights!!!!
After watching your pulls I think I may have a bad overflow valve or lift pump. My 64/14 can clear up the smoke by mid-track (the temps are off the chart though). I would think that with our pumps being similar (laser cut dv's, 435's, recalibrated pumps) that your bigger turbo would clear better unless it isn't spooled up as much (but it sounds like it is). I'm also running a #100 plate that is set in the middle and a very tight star-wheel so may down on fueling. I may have to drop a new overflow or at least check fuel pressures. Also having some rough idle and tranny issues after last pulls
Garret, are you running a FASS or other aftermarket fuel pump?
Keep up the great pulls.
Paul
Old Jul 5, 2007 | 01:15 PM
Bobcat698's Avatar
Paul
Thanks!, About the weights, that was only at 7500lbs! (stupid weight rule)
Currently I have a nicely tuned 215HP pump on my truck.. its around 460ccs.
I am only running 191's at the moment as well.
I ditched the stock fuel system and use an Aeromotive 1000 pump, 10 micron filter, and 5/8's stand tube to -10 line to the pump.
Old Jul 5, 2007 | 01:58 PM
Paul Winey's Avatar
7500 #! What did you have to throw out to make weight
Now you really make me wonder about a fuel pump. My 180 pump was tuned to 433 cc's with some 191's before I had the lazer cuts. I know that 30 cc is a lot of difference but I would think the turbo size could/should compensate for that. I'm not unhappy that I don't blow black smoke all the way down the track but I'm not sure I'm getting everything out of it I could. It pulls hard and doesn't fall off just looses traction. It does dump a lot of fuel early so I may be better off going back to the 191's. I'll have to check fuel pressures sometime and maybe a high-flow pump is in the future. Thanks for info.
Old Jul 5, 2007 | 02:18 PM
Bobcat698's Avatar
I added 250lbs and was good to go!
Let me know what you find with the fuel system!
Old Jul 13, 2007 | 01:36 AM
Bobcat698's Avatar
This hook in my opinion is the nicest looking one all year, it felt GOOD!
Too bad it was only a test hook, I broke the front driveshaft cv joint on the "official" hook on the launch
Old Jul 13, 2007 | 02:21 AM
Common's Avatar
The single stack looks great!
Nice truck, man - its amazing what talent can bring to a 12v...
Great job!
Old Jul 13, 2007 | 10:27 AM
Joker12valve's Avatar
Truck looks good garret, hope it dosen't keep breaking on you thought. How dose it drive on the street?
Old Jul 13, 2007 | 12:29 PM
Rodram2002's Avatar
Your truck is hauling some butt! what kind of wheel speeds are you seeing? do you have air bags or blocks in the back?
