Gauges
Old Aug 23, 2008 | 01:58 AM
daddy mopar's Avatar
Question Gauges
I am looking at getting the Autometer C2 gauges for my pickup. Can anybody give me any advice about other gauges? What is the temp range I should be looking at for my transmission, PSI/Vac for my boost and temp for my PYRO?
Old Aug 23, 2008 | 02:20 AM
mt_rodeo's Avatar
good choice for gauges! i too am gettin the c2's. im lookin at either 0-60 or 0-100 psi for boost. pyro either 1600 or 2000
Old Aug 23, 2008 | 09:46 AM
duner's Avatar
you won't have any use for a compound boost gauge.
Old Aug 23, 2008 | 11:25 PM
Flatbed24v's Avatar
I run the phantoms my boost is 0-60 psi and my pyro goes up to 1600 I would also add a fuel press gauge to your list IMO that is one of the most important gauges next to pyro
Old Aug 31, 2008 | 11:39 PM
What are the parameters of your guy's trucks? boost, pyro, fuel, trans?
Old Sep 1, 2008 | 01:25 AM
smokin95's Avatar
boost 0-60 pyro 0-2400 trans temp 0-280 fuel pressure 0-100
Old Sep 1, 2008 | 02:05 AM
Tate's Avatar
I'd go 0-1600 on the pyro. If you are doing short blasts, pegging the pyro isn't a real issue, and if you're towing, temps below 1600 will cause harm. Good to have your average reading in the middle of the range.
Boost 0-60, unless twinned, then go 0-100
Pyro 0-1600, maybe 0-2000 if you really want it
FP 0-100 on a 12v, 0-30 on a 24v
trans, I have no idea, never been a concern for me.
Old Sep 1, 2008 | 02:33 AM
Western Rammer's Avatar
The thumb rule for all mechanical guages is that they're only really accurate in the middle 1/3 of the range. For instance: a 60 psi boost guage will be most accurate between 20 and 40 psi. How much beyond stock do you expect to take your truck?
Randy.
Old Sep 3, 2008 | 10:49 PM
smokin95's Avatar
i agree that 1600 is plenty hot but i see temps up to 1400 degrees so i figured the 2400 would be alright and its the only one they had in the style i got
Old Sep 3, 2008 | 11:45 PM
wcbcruzer's Avatar
Here's mine
EGT - up to 1600
Boost - up to 35
Mechanical fuel pressure - up to 100
Trans - up to 250 (I think)
My boost gauge is too low for some, but I really like it because with normal driving the needle noticeably moves around.
Old Sep 18, 2008 | 01:22 PM
Its all a big help guys and girls, I am just trying to figure out what my parameters should be when i choose a gauge. Any advice on mechanical or electrical gauges. I am thinking all electrical?
Old Sep 18, 2008 | 05:04 PM
wcbcruzer's Avatar
For pressure gauges, I wouldn't trust an electrical one. Some of them come with isolators, those are even worse.
Old Sep 19, 2008 | 03:35 AM
Tate's Avatar
I run full electrics in both trucks, no real issues to speak of.
Old Sep 19, 2008 | 03:57 AM
Big Smoky's Avatar
I had the C2's and they looked great, but were WAY too bright at night. Make sure to get a dimmer with them, so you can still have the dash lights on, and you'll love them.
Old Oct 7, 2008 | 01:34 AM
Guages?
What gauges do you prefer, on my old Chevy I had trans, pyro, and boost. Most of you are saying i should have pyro, boost, and fuel? Or should I find a place for all four?
Where are you placing your sending units? Ie.. Exhaust manifold, transmission pan, exhaust side of turbo, fuel pump?
