Gauge Mechanical/Electric best choice
Just one qustion about gauges: I want to install a fuel press gauge to take an eye on it (i have a 99 ctd with the famous VP44); I have found mechanical and electric gauge, what's the differences? what's best for my truck? (I saw that mechanical are much expensive than electr.) what's the easy-install?
thanks to all guys.
ROB
thanks to all guys.
ROB
both are easy to install, mech. are cheaper and from what i heard last longer. some people use an isolator i have not. i just ran a small needle valve just in case it leaks and to also cut down on the pulses. electric you tap a hole thread a sender then run your wires, but some gauges cant take the pulsating and fail. i chose the mech. because if it fails there much easier to replace, no wires and Hella cheaper. $40 compared to 150 or so.
I chose the Quadzilla Commander. For about $300 you get 4 gauges displayed simultaneously, with alerts, custom defueling aprameters, and min/max data. It monitors more than 4 things, but you can display 4 at a time.... It also controls some chips/modules.
thanks a lot! I want a fuel press gauge that mount in a single pillar pod and I'll monitor the other parameters with a Commander, I'll get it for next mod very soon. 1 gauge only because I like the single pod, only for this, dont like the 3pod pillar because i think its too much restrictive of drive view...
I have a stock truck, I'm waiting my EDGE EZ next week and plan on exehaust and intake.... fuel press gauge 0-30 psi can fit my ride? or 0-60 0-100...
From what I have noticed, mechanical gauges usually have a 270* sweep and electric gauges have a 120* sweep. I like the larger sweeps since there are more graduations and more movement in the needle.
Ronnie
Ronnie
nrussell
Jul 23, 2008 08:58 PM
mike moore
Feb 27, 2008 06:26 PM
Scrambler250
Feb 17, 2004 01:22 PM
commando
Dec 2, 2002 12:26 PM
