Fueling
Old Dec 16, 2010 | 11:28 AM
old smokey's Avatar
Fueling
I have a 98.5 24 valve with a edge juice with attitude and a raptor 150 pump. It seems like the fueling dies off after about 2200 rpms. Should i do injector nozzles or smarty programmer first? If nozzles how big?
Old Dec 16, 2010 | 12:42 PM
johnyb59's Avatar
How much power do you want to make?
Old Dec 16, 2010 | 02:46 PM
sloth's Avatar
Check your egt setting for the juices backdown program?
Old Dec 16, 2010 | 02:47 PM
sloth's Avatar
Also, is the pump tapped?
Old Dec 16, 2010 | 03:19 PM
old smokey's Avatar
Im eventually looking for around 500 hp but for now its one mod at time. My pump is set at 18psi at idle and will drop to 14 under full load with edge maxed out. The edge alone just isnt enough. It pulls great until about 2200 then just plains out. I want nozzles and smarty but dont know which one first?
Old Dec 16, 2010 | 07:28 PM
sloth's Avatar
But is the vp tapped? Personally I would go with injectors before another programer, and if you have your settings too low the edge will defuel after a certain why or boost level. On mine with hot unlock it pulls hard up to about 3k but never really falls on its face, you may want to play with edge and see what happens.......
Old Dec 16, 2010 | 09:05 PM
Dinner's Avatar
I agree^^
First make sure the VP is indeed tapped, and tapped correctly. Something doesn't seem right, the Edge's (non drag or comp versions) should fuel to 2800 I believe.
mudracer
14
Jun 7, 2003 02:38 AM
AKDSLDOG
Jun 1, 2003 04:33 PM
Davidp
Mar 19, 2003 11:29 PM
Missouri_Mule
Dec 16, 2002 12:20 AM
