fuel pressure readings
Old Oct 2, 2004 | 06:02 AM
jj3500's Avatar
FP guage in now...at idle 15, most cruising w/o load 15, the harder i hit the throttle the more movement i see in the guage. the most radical change i had seen is a momentary reading of 9lbs., of course WOT. can i assume this is just normal.....hoping that it is.
thanks all
westach FP guage, 18" fuel line attached to the schrader valve...sending unit. 45degree elbow in kit...not used.
Old Oct 2, 2004 | 07:25 AM
More Power's Avatar
Yes the change in fuel pressure is normal most people say to stay above 8 psi and your fine but i have also heard you can go as low as 6psi.
Geico266
Oct 27, 2004 07:07 PM
jj3500
Sep 5, 2004 07:12 PM
ernod
Aug 20, 2004 01:05 AM
kevlar
Apr 30, 2004 12:42 PM
cmckinney
14
Mar 4, 2004 09:51 AM
