Fuel boss mechanical lift pump
hello all. Looking at buying a fuel boss for my pick up here in about 2 weeks and was wondering if anyone who is running one is running it all mechanical, meaning you no longer use the electric as a back up. This is what I was wanting to do but was curious as how priming the filter goes without the electric pump. Do you use a drill or something to spin the pulley?
Have you done any research on the 'net about this? Have you done a search here and on the internet under "Fuel Boss"? There is a lot of info out there.
Let us know what you eventually decide to do and the results. |
I had a rasp pump on my 01 same type pump. Had no problems with it for 200k outside of the seal would need to be changed occasionally. I never had a problem with a fuel filter change. If you do just need to crack a couple injector lines 1 at a time crank the engine until you see fuel coming out then tighten down and move to the next one. When doing fuel system work I never needed to crack more than3. I don't recall having to do it at all for a filter change
