Free Gsk?
one washer above each set of springs (2 washers)
get a 3/8" washer drill it to 1/2" or a bit more, so it'll fit over the cone on the top spring retainer, outside diam has to be a lil less then 1"
leave the springs a bit looser then they where stock!
good luck!
good luck!
on the side is a plug (right under the fuel shut off solenoid. you remove that with a 7/8 socket.
then you have to turn the motor thill you see one set of springs, put a washer there,
next turn the engine a whole turn, thats the other springs set
(pump turns half the speed the engine does!
https://www.dieseltruckresource.com/...ight=free+pump
http://www.piersdiesel.com/TechGSK12V.htm
SHARPMACHINE
Mar 6, 2007 08:45 AM
MR HYDROSEED
Mar 9, 2005 10:49 PM
Got Smoke?
Oct 26, 2004 03:57 PM
