Fire Ringed head and boosted to 84 PSI
Old Sep 29, 2005 | 11:31 AM
  #31
Don M's Avatar
DTR Advertiser
Typically, 84 PSI is too much. The most power in the 24 Valve is made in or around 70 PSI MAX with the class turbos you are running.
Air that is higher in pressure is, as a rule, higher in temperature. The balancing act is to get the density high, while watching the air temps. The air ( oxidizer ) needed to crack/burn the fuel parcels is what makes the added power. If the air temps are too high, the balance tips toward the negative and less boost ( pressure ) can have a higher number of oxidizers per cycle.
Don~
Old Sep 29, 2005 | 11:37 AM
  #32
SpicyJam's Avatar
Thank you for the typing error, sorry.
No I meant 65psi for a O-ringed head, there is a difference. I do both O-rings and fire rings at the shop, but when I show the wire for a O-ring job and the actual fire ring and gasket to customers they tend to go with the fire ring, I have yet to do a O-ring job on a truck, the wrapping is still on the wire. I wouldn't recomend running 84psi with just an O-ringed head. Just stating my .02 cents thats all.
I do know of one truck that he cut O-rings in and with his twins he is making 57psi and so far has no problems. Just not my prefered method, as rule of thumb seems to go with some people, they seem to always want more.....
The twin set ups that I have been building using a PDR40 and a HT3B have been right around 67 to 70 psi. So I feel a little safer offering the fire ring.
Old Sep 29, 2005 | 12:59 PM
  #33
pmtg's Avatar
still want to know how carbon builds up in the intercooler...
Old Sep 29, 2005 | 02:01 PM
  #34
justinp20012500's Avatar
What about the pumps???
Old Sep 29, 2005 | 04:51 PM
  #35
pmtg's Avatar
the pumps? meaning air pumps/turbos? would this be a result of oil bypassing the seals on the shafts of the turbo/s?
i've never heard of carbon buildup in the intercooler, just wondering its causes...
TIA
Old Sep 29, 2005 | 08:58 PM
  #36
DR3500's Avatar
What exactly do the fire rings look like? I am under the impression that they are a C-shaped ring that has the open end of the "c" is facing in, am I correct?
Old Sep 29, 2005 | 09:04 PM
  #37
sleds's Avatar
Old Sep 30, 2005 | 05:52 AM
  #38
SpicyJam's Avatar
No they are a solid steel round ring, that you cut grooves for in the block and head. The gasket you get has the fire ring, (the metal ring on a original head gasket) removed, and you use the round seemless ring in its place.
Old Sep 30, 2005 | 06:23 AM
  #39
storx's Avatar
my old turbo before i put the twins on were shot and leaked oil like it was cool........im not totally sure if it was carbon buildup or a buildup of oil with some carbon look to it but it was black, nasty, and it had to be cleaned
Old Sep 30, 2005 | 10:16 AM
  #40
Old Sep 30, 2005 | 12:31 PM
  #41
DR3500's Avatar
So it is basically just a larger steel version of an o-ring? I know the o rings use the regular version of the HG. How are the o-rings better than stock? I know they can work but I don't understand why.
Old Sep 30, 2005 | 03:03 PM
  #42
storx's Avatar
just so yall know this was a one time try to see what she dish out... im running 48 psi daily driven......
Old Sep 30, 2005 | 03:09 PM
  #43
Mike D's Avatar
I want to see pictures of the twins, show them off dude!
Old Sep 30, 2005 | 03:27 PM
  #44
storx's Avatar
how far is rural hill from me?.....im always traveling so maybe i can show you in person
Old Sep 30, 2005 | 03:36 PM
  #45
Mike D's Avatar
Actually, I'll be in your neck of the woods this weekend. I'm heading home to New Bern to see my folks. We could meet some where and talk diesel. Are you a memeber of the NC chapter yet?
diezel freak
Oct 28, 2009 06:56 PM
Bswope
Apr 11, 2009 11:14 PM
Bjans
Feb 4, 2009 11:11 AM
mhuppertz
Nov 10, 2006 11:12 AM
clawson
Jan 12, 2006 08:52 AM
