engine will not turn off
Old Oct 16, 2003 | 06:00 PM
dodgeman01's Avatar
Well I was working on my 4k gov kit trying to get it figured out because I have been haveing a few problems with the truck being jerky and all was going well. just figured I would crank the gov springs down 2 more clicks and be done with it. WRONG!!! now when I turn the "key" off it either takes a few minutes or will not at all shut the engine off. looked at the shut off silenoid works like a charm. checked it with the trucks running unpluged it and pushed the arm to shut it off and it did the same thing :not turn off" truck runs great it is right where I want it. It would be nice to beable to stop the truck w/o stalling it :'( :'( :'( :'( :'( :'( :'( :'( :'(
DM01
Old Oct 16, 2003 | 06:21 PM
dieselcrazy's Avatar
Re:engine will not turn off
somebody help dodgeman .......... this sounds awfull ( the not shutting down part that is )
Old Oct 16, 2003 | 11:55 PM
dsljunkie's Avatar
Im not saying you didnt check it out fully but, mine did the same thing and it was in the shut off solenoid. Check the turnbuckle adjustment on the plunger. If theres nothing wrong there take the shut off sol. completely off, unplug it and operate the lever manually. If it still wont shut down Id say you need to back off your gov. springs a click and see if that helps.
Good luck
Scott
Old Oct 17, 2003 | 09:27 AM
Don M's Avatar
DTR Advertiser
The engine WILL shut down if the solenoid is working properly.
It simply rotates the plunger angle to not pump fuel by opening the spill port. No pressure to open the injectors.
I have had one hang up. At 5000rpm I scored a plunger. The plungers all being connected together cant rotate back if even one of them sticks. It also roached a pump cam. Expensive mistake. The only way to shut one down in this case is an air shut-off.
Check your solenoid adjustment and I am certain you will find the trouble.
Old Oct 17, 2003 | 09:32 AM
dodgeman01's Avatar
aright thanks guy I will pull her apart this weekend and check her out.
Thanks
again
DM01
ChicagoSnow
May 11, 2008 08:52 AM
stealman1
Nov 9, 2007 11:07 AM
expressfish
18
Mar 11, 2007 04:28 PM
zachv
Jan 24, 2005 10:46 PM
