electrical guru wanted
Old Jun 17, 2006 | 10:14 PM
JW3's Avatar
JW3
just got my westech fuel gauge assembly, Ive noticed that the wires are going to be too short.I assume that u just splice an adequet lenght of wire to make any and all connections ? I am using an isolator off the vp44.
Old Jun 17, 2006 | 10:52 PM
ctdnwakulla's Avatar
Yes you will need to splice the wire needed to install your gauges. If you want to do it right,you will need to solder each connection and use heat shrink to seal the splice.This will also be a much cleaner installation. I would also suggest that you use a little more wire than needed,just in case you need to address a problem later. Use wire ties to secure your wires ,but leave some slack between. Hope I have helped
Old Jun 18, 2006 | 09:13 PM
JW3's Avatar
JW3
thanks
That made sence,but u hate to burn something up unintentionally. thanks for the 411.
Old Jun 18, 2006 | 09:25 PM
storx's Avatar
dont use an isolator... i had one and it leaked shortly after i started to use it...
I now have an gauge manifold like what they use in drag racing and such... there awsome and they are very useful if you want to pump your return into the manifold and regulate some of the fuel back to the tank so you can take some of the strain off the lift pump....
http://www.mcmaster.com/
part # 5469K31
here is an example of it....
dizzel
Jul 31, 2009 07:54 PM
Luvnacumns
Apr 8, 2007 12:39 AM
JW3
Jul 7, 2006 08:12 PM
fitzer
Aug 8, 2004 06:55 AM
Jbolt001
Nov 11, 2002 07:35 AM
