eknob
Old Feb 20, 2006 | 03:07 PM
ramcummins's Avatar
eknob
Has anyone used one of these http://www.genosgarage.com/CoastalDa...D=1473&CATID=1
If so, how do you like it? What types of brakes will it work with?
Old Feb 20, 2006 | 07:05 PM
infidel's Avatar
In installed one in a '97, thought it was pretty slick. The fellow who I installed it for hasn't had any complaints and knowing him the way I do I'm sure he would complain if there was a problem.
Old Feb 20, 2006 | 07:12 PM
Andy505's Avatar
I think it is just an electric on/off switch...should work with any brake....or anything else that runs off of electricity
Old Feb 20, 2006 | 08:12 PM
Moose10's Avatar
I had thought about it, but it seems to me like it may be activated or de-activated by accident with the switch on top the shifter. I like the Cummins switch that goes on the stick, but it's around $80 I think I'm going to try to get an airbrake push/pull **** off a bus or truck and use that instead somewhere.
Old Feb 21, 2006 | 08:08 AM
Ph4tty's Avatar
It says the switch is recessed. So for those of you who have seen these in person, you could palm the top of the shifter without hitting the button, then you'd hit the switch with a finger or thumb?
