Edge Comp and SSssssmoke....???
Old Jul 27, 2003 | 10:53 PM
BigBlue's Avatar
Re:Edge Comp and SSssssmoke....???
I haven't hooked my new Comp up yet in COMP mode because so I can't tell you. But in EZ mode, it smokes pretty good.
Old Jul 28, 2003 | 01:22 AM
geer's Avatar
Mine doesn't smoke much only when you are in third at low speed then give her the onion. I have only ran it on 5x5 so I have no clue what it does on the other settings.<br>Scooter
Old Jul 28, 2003 | 09:45 AM
TxDieselKid's Avatar
Had to pull my injectors for a little testing, so that now all I have is my COMP, and there is hadly ANY somke. Even with the box on 5x5, and me flooring it from a dead stop. <br><br>Tell you what I'll do though. Send me your box unit, and I'll send you mine. Well see if it's your box, or mine, or....??? . <br><br>
Old Jul 28, 2003 | 01:17 PM
hellotbone's Avatar
When I have my box turned on and the EDM stage 2's on level one I get hardly any smoke at all when its on 5 though look out! I have a box about 1.5 years old so whatever program is in there is what I have.
Old Jul 28, 2003 | 03:06 PM
Haulin_in_Dixie's Avatar
As I understand it the EZ is the same as the Comp on the first three settings. So this may have some info. I installed the EZ on the stock motor and got a fairly good amount of smoke at shift points. Next I installed the RV275's adjusted the valves (one intake abt .0004 open) and this gave it a heavy smoke at shift points, I worried that I might have to come down on the setting of the EZ for my commercial use. Next I installed a new map sensor and the smoke went down considerabley. Now with the 275's and the EZ on the most agressive setting, I can ease off with no or little smoke, there does not seem to be any smoke (in the mirrors) on pull once spooled. If I agressively wind through the gears there is a strong belch of smoke at shift points but I can ease off at the scales without getting too much attention. I am totally satisfied with the smoke situation. It looks like the MAP sensor can have an effect on the smoke emitted.
Old Jul 28, 2003 | 03:48 PM
KatDiesel's Avatar
[quote author=Haulin in Dixie link=board=7;threadid=17596;start=0#164929 date=1059422765]
As I understand it the EZ is the same as the Comp on the first three settings. [/quote]
That is incorrect if your refering to the &quot;Levels I, II, II&quot;, it only equals the EZ in Level I. Now if your refering to the SubLevels then that might be a lil bit closer to believe.
Old Jul 28, 2003 | 04:59 PM
StakeMan's Avatar
You should post what version number your comp has so you are comparing apples to apples.
Old Jul 28, 2003 | 05:10 PM
[quote author=Jamie Attridge link=board=7;threadid=17596;start=0#164898 date=1059416223]<br>When I have my box turned on and the EDM stage 2's on level one I get hardly any smoke at all when its on 5 though look out! I have a box about 1.5 years old so whatever program is in there is what I have.<br>[/quote]<br><br>Thought those things didn't smoke? Just kidding.<br><br>Stake, very valid point. I have a much older version of the box, and thought it might give some feedback that he was looking for. <br><br>Andrew
Old Jul 28, 2003 | 05:16 PM
StakeMan's Avatar
[quote author=Gary - KJ6Q link=board=7;threadid=17596;start=0#164993 date=1059430158]<br>Version 7 - just like the first one was...<br>[/quote]<br><br>Why would they reflash with the same version?
