On the Dyno with CTD2001...
Originally Posted by Big Deezul
when you dyno do you lock the TC?
But that didn't happen to me.....
I had a good time yesterday, it was fun to meet everyone and talk trucks and watch them pull on the dyno, it was worth the trip down for sure. My dyno numbers were 458.9hp/1014 ft lbs of torque. That was with the set up in my sig and with a MAD ECM that i was trying out.
Originally Posted by NOSPIN4ME
My truck...347HP and 777TQ. See mods in sig. Stock injectors and stock turbo.
The HY-35, over 32 psi boost is actually costing you HP, IMO.
Nice numbers for what you've done so far.
RJ
Originally Posted by rjohnson
I assume you already know this......An HY-35 on a Drag Comp is like a dog lease on an elephant. ANY bigger turbo would be worth 30 more hp. The right amount of air would probably be closer to 45 hp!
RJ
RJ
Originally Posted by Bob Wagner
Does the catcher make your 40 spool quicker? Great numbers
Made the ECM swap, drove the truck and then turned screw down on the pump cover to make the connection.
He did not make a pull with just the addition of the ECM. And that's too bad, would have been nice to see the numbers the ECM added by itself.
The next time on the Dyno he made the big numbers.
So anyways, I can't answer your question Bob, just figured I'd add this info.
Bob, the Super 40 spools very very fast, practically no turbo lag at all, there is a big big difference between the stock ECM and the MAD ECM. How does the high idle feature work on the MAD ECM? Does it bring up the RPMs at idle when it is a certain temp? I am curious, I have not been out to start the truck today so i was not sure, thanks
pwerwagn
Feb 28, 2007 03:18 AM
502502
23
Nov 23, 2005 06:16 PM
