DV holder restriction?
Old May 15, 2007 | 09:46 PM
TheBigNasty's Avatar
I was just meddling around with my friends DV's earlier and noticed the really really small hole all of the fuel has to go through to get into the lines. My question is, is there a reason there is such a small orifice?? Seems as if the hole was made as big as the ID of the injection line it would flow so much more.
Old May 16, 2007 | 10:35 AM
bump.......
Old May 16, 2007 | 12:26 PM
patdaly's Avatar
LOL, Im pretty sure you need that small hole to restrict the flow....
Old May 16, 2007 | 12:52 PM
....I don't get where you are going with that?
logskidder's Avatar
To maintain a given amount of pressure. A bigger hole will flow more fuel, however with all things being the same....it will also lower the pressure.
Old May 16, 2007 | 12:55 PM
True, but once the lines are filled they will hold the pressure I would think. Only thing I would see if it is to build the pressure so the injector doesn't pop off too soon.
Old May 16, 2007 | 02:54 PM
WUnderwood's Avatar
well, they make bigger injector lines and delivery valves, right?
might want to call Piers and see what he thinks, thats definately thinking outside of the box, which is good
Old May 16, 2007 | 04:02 PM
logskidder's Avatar
All things being the same.....as flow increases, pressure decreases and you can't change that.
Old May 16, 2007 | 04:17 PM
AlpineRAM's Avatar
While that's true there is something to consider- the impediment to flow should be the injector, anything between injector and pump should flow "enough" - the pressure you talk about is only before the injector line and I don't see that a pressure drop between the IP and the injector is beneficial- but on the other hand it could either be necessary to restrict the flow there as not to burst injector lines or have some other reason I don't know.
Asking Piers or any one of the other fine P-Pump savvy folks is a good idea.
AlpineRAM
Old May 16, 2007 | 04:18 PM
Paul Winey's Avatar
They are just one more device to meter and control fuel volume and pressure. Due to laws of physics if you double the diameter you will increase flow 16 times (some law of physics I long ago forgot the name of).
They do make larger DV valves 131, 181, 191 and laser cut. Each has it's advantages depending on the pump and desired fuel volume.
You would be amazed at how much fuel a tuned P7100 pump can move. 800 - 900+ ml's of fuel at 3000 rpm in a race pump is not unheard of or higher. That's nearly a quart a minute.
The 160 pumps had a smaller DV. That is why many update to a larger DV when going with larger injectors to keep up the flow and reduce engine stumble.
Old May 16, 2007 | 04:35 PM
logskidder's Avatar
Yes you can get different DV's....but is the hole in the holder bigger,smaller or the same ????
Old May 16, 2007 | 05:29 PM
Yeah, the hole which I refer to is in the holder.....well I guess the holder holder. The part the injection line screws onto. It is like a pinhole in there!
BTW Will, Piers very conspicuously said they did not know what we were talking about.
Old May 16, 2007 | 06:14 PM
logskidder's Avatar
Run a 1/4" drill through it........then you'll get her to flow
Old May 16, 2007 | 06:21 PM
Yeah, but is it a pinhole for a reason? Cause if not that is kinda my idea. Shoot I guess I just need an extra set so I can drill it and try it.
Old May 16, 2007 | 07:43 PM
BigBlue's Avatar
Why not. It's a p-pump. What can it hurt.
