DSS not working with lift
Old Aug 21, 2006 | 09:35 PM
arroyojim's Avatar
anyone out there with a DSS (http://www.solidsteel.ca/DSS.htm) and lift kit? i called the guys who make this and told them about my lift...2.75" drop brackets for anti-sway bar, nothing between them. guy said it should work fine but when i went to line it up tonight the bracket was at least an inch below the end of the extended pitman nut. am i missing something here? i know the sway bar is not 100% essential, but i live up a canyon with some tight turns-curves-switchbacks and wouldn't mind keeping it on there, just don't see how it could work. will call windecker in morning, but might sleep better if anyone has any info..
many thanks
Old Aug 21, 2006 | 09:58 PM
y2kram's Avatar
between drop-down brackets and frame
It will mount between the sway bar drop-down brackets and the frame. Works fine. I have a 4.5" Skyjacker (and it has the spacers for the sway bar) and it went on with no problem at all.
Old Aug 21, 2006 | 10:04 PM
BigBlue's Avatar
Same here. Just bolt the brace to the frame first and then the drop brackets and it'll work perfectly.
Old Aug 22, 2006 | 07:08 PM
phox_mulder's Avatar
many thanks
Might get better results calling Solid Steel, pretty sure Windecker has closed.
www.solidsteel.biz
phox
Sleigher
May 4, 2017 02:12 PM
isissound
Oct 11, 2009 04:18 PM
fitzydog
May 15, 2007 10:11 AM
arroyojim
Aug 22, 2006 07:18 PM
JackRAK
Apr 23, 2006 10:33 AM
