Drag Comp - EGTS??
Old Sep 8, 2003 | 09:48 PM
turbo lcc's Avatar
Drag Comp - EGTS??
My setup:
DDII
DTT 89%
PDRHX40
Drag Comp
with the comp on setting 1 sub level 4 I can hit 1400 pre turbo and 38lbs of boost..
How does this compare to the rest of you?
Thanks
Lynn
Old Sep 8, 2003 | 10:11 PM
Racer57's Avatar
Re:Drag Comp - EGTS??
Man, thats pretty high for that low setting. How long are you keeping your foot in it? I see 1600 briefly but that is at the end of the quarter mile and running a drag comp on 5x5 of course.
Old Sep 8, 2003 | 10:48 PM
turbo lcc's Avatar
you should see it on 3x5 ...
Old Sep 8, 2003 | 11:28 PM
LE's Avatar
LE
Does the Drag box improve 1/4 mile times? I have seen dyno results with nothing added except heat. Just curious... LE
Old Sep 9, 2003 | 10:13 AM
PourinDiesel's Avatar
The Drag Comp from Edge is awesome.
After I had mine upgraded, I went out and tested the unit and my truck and
Faster, smokier, hotter.
Better.
--Justin
Old Sep 9, 2003 | 10:55 AM
OlBlue's Avatar
Same setup, 'cept 6spd and lotsa porting and polishing. I get 32psi 1250deg pre turbo with Drag Comp on 1 main, sub anything. Sub helps get fuel added quicker, but doesn't really affect top end.
joefarmer
20
Dec 11, 2004 05:25 AM
White00
Nov 19, 2004 09:18 PM
ratsun
Sep 26, 2004 11:16 AM
MoreSmoke
Jan 7, 2004 09:40 PM
hellotbone
18
May 16, 2003 04:40 PM
