does a rubber o ring go on each injector?
Old Apr 20, 2009 | 01:01 PM
1320's Avatar
12 valve.....does a ruber oring go on the lower groove in the injector? I never had them before, just themetal ring on the upper groove. But on the rebuild I have a package of injector parts, washers, return line brass peices, and 6 orings, that appear to fit perfectly on the lower groove of the injector.
Old Apr 20, 2009 | 01:15 PM
BigErksG2's Avatar
the rubber orings are for after you install the injector and the injector nut. It goes between the injector and injector nut but do it BEFORE you put the injector lines on. Make sure you use the same thickness washer on the bottom end of the injector as what came off.
ImpulseHydro
Oct 5, 2007 07:04 PM
kevellis32
Apr 18, 2007 09:06 PM
HaulinBut
May 12, 2006 03:06 PM
I PASS GAS
Jan 5, 2004 08:48 PM
pwabbott
Nov 28, 2002 01:10 PM
