Do I need head studs
Old Mar 4, 2007 | 11:30 AM
jeeptjstud's Avatar
Check my sig. I am planning on upgrading to a SP 64 or 66 turbo with a little bit bigger injector (say Mach 4.5 maybe 6's) Do I need to install head studs before this
Old Mar 4, 2007 | 12:06 PM
blackdiesel's Avatar
Registered
yes
stupidcharacterlimit
Old Mar 4, 2007 | 01:26 PM
dzlfarmboy's Avatar
You could try your luck on the stock head bolts I ran on mine for a while with the Mach 7s but i was only running 45lbs of boost and it finally went after like 5 months but eventually you'll need some studs
Old Mar 4, 2007 | 01:32 PM
Registered
to properly get the horse power from the larger turbo, box, and sticks you will NEED studs. With out them, you will only be able to safely boost ~43 psi. With them, you will be able to boost ~50 psi safely. and it will be alot more reliable
Old Mar 4, 2007 | 01:49 PM
cumminsdriver635's Avatar
It depends. I have seen an O-Ring'd head with stock studs make 630hp on a 12 valve with no problems. Not sure on the boost #'s, but he was running a pro street 66 i believe.
Eric
Old Mar 4, 2007 | 02:08 PM
BigBlue's Avatar
I've run 40+psi for well over a year now on the stock headgasket and head bolts with no issues but it varies from truck to truck. You might not need them now but I recommend you install them as soon as you can just for the piece of mind.
Old Mar 17, 2007 | 01:16 AM
Ph4tty's Avatar
My boost is down enough now where I'm wondering if I really do need studs Always less than 40 lbs of boost in my now underfueled rig.
Old Mar 17, 2007 | 03:23 AM
PourinDiesel's Avatar
No you dont need studs. They are a good insurance policy though if properly installed.
Old Mar 17, 2007 | 03:36 AM
cumminspower79's Avatar
Hey jeep, this is a little off topic but you have GOT to post a pic of that 7" exhaust tip!!!!!!!!!
Old Mar 17, 2007 | 08:10 AM
Jetpilot's Avatar
I you want to not worry about loosing a headgasket then installing studs is good insurance. A good rule of thumb, below 40# good ont OEM stuff, 40# but below 50# install studs, above 50# you should consider o-rings or fire rings.
I have seen stock trucks blow HG's and also seen trucks push well beyond 500 RWHP on the OEM setup. Each truck is different. I can say that it is much easier and cheaper to install the studs than to replace the HG and flush the coolant and oil systems.
Doug
Old Mar 17, 2007 | 10:22 AM
Registered
i dynoed 529 on the stock HG and bolts. Spraying water meth. i was boosting around 48-49 psi., but I wouldn't recamend it
Old Apr 19, 2007 | 06:31 PM
Truckman's Avatar
Question Question
Doug
Not to change the subject BUT ,, I am going through a headgasket leaking problem Now,, I hear all this talk about head bolt retorque Can you retorque a stock headgasket and bolts? with 30000 miles, If I understand correctly,,, You can remove the head bolts,Clean,Lube and reinstall,without changing the gasket? Torque To Factory specs? 2001 CTD
I have never heard of this,,, I HOPE its True,,
Can You post steps?,, Do you do one bolt at a time? or remove all and reinstall ?
I should have never put that Edge Comp on,,
Thanks
Old Apr 19, 2007 | 10:44 PM
Thanks
Yeah you can do it. One at a time. Do a search on it.
Old Apr 19, 2007 | 11:01 PM
03qclb5spd's Avatar
Doug
I am going to stop playing with the forrest fire really soon, but i'm still running the stock head bolts in my 03. Dyno'd 525/996 at 55 psi on them. I'll definitely be getting the studs asap.
Old Apr 21, 2007 | 07:46 AM
Truckman's Avatar
Talking Just MY luck
Just my luck to get a NEW CTD that cant handle all stock except a Edge Comp With the boost elbow in and the head gasket starts leaking 200 miles after install.....
After I get that done ,,it should be time to start allover again with Ball joints,track bar,5th gear,etc.......... It's a Vicious circle...
I think it's time to SELL,,,,,
Thanks for everybody's help.
