Diprocal lighting
Old Apr 27, 2005 | 06:05 AM
HOdiesel80's Avatar
Diprocal lighting
Gauges are all installed and look great. Fuel pressure is a bit of concern at 8-10lbs at idle and only around 5 lbs at WOT. Anyway I bought Diprocal white faced FP, Pyro, and Boost. Problem is they aren't what I would consider very bright at all. I spliced all the wires together minus the pyro and ran them to an add-a-circuit fuse. I connected the fuse to the Illum. fuse. I wired my pyro with another add-a-circuit to the IGN fuse. They are all dim. I can see the main numbers but not the red needle and are hard to read. My illumination switch is up all the way. Does anyone know what my problem is???????? If it's just the way diprocals are,then does anyone know where I could get some stronger bulbs??????? Thanks in advance.
Old Apr 27, 2005 | 07:12 AM
Jetpilot's Avatar
Mine are the same way..... Let us know if you find some brighter bulbs.
Doug
Old Apr 27, 2005 | 07:14 AM
2500CTD's Avatar
Not sure of the illumination switch with them, but as a general rule check the voltage to the lights, ya might have a bad connection, either on the + or- side. just an idea.
Old Apr 27, 2005 | 08:25 AM
BoostdCTD's Avatar
I'd be weary about putting higher output bulbs in, it seems like any bulbs 5w or higher can melt plastic if there is no moving air.
Old Apr 27, 2005 | 11:17 AM
Flatty's Avatar
Mine are the same. I was talking to my bro and we discussed these gauges in some depth. We always run Auto Meter gauges in all our Rock crawlers. This was the first time I ran some Di Pricol gauges, and I am glad I did. They kick ***!!!! I have yet to see Auto meter come out with a 1-30 FP gauge. The lighting may suck, but I think you will get used to them in time.
Dima
Old Mar 2, 2006 | 10:16 AM
sabo.mso's Avatar
Dipricol Lighting - Spare Bulbs
There are a variety of Diprocal spare bulbs in different wattages here:
http://www.usdieselparts.com/category.cfm?Category=1149
Might be worth checking out...
Old Mar 2, 2006 | 01:34 PM
big jimmy's Avatar
I have mine on the dimmer switch and noticed no problems. No, they are not "bright" but I have great vision and don't like my gauges taking from me the night vision outside the truck.
Rugged gauges that are accurate too.
Big Jimmy
Old Mar 2, 2006 | 01:48 PM
gmctd's Avatar
Modern gages have plastic back-lit faces - light shines thru the gage face - where the older styles had aluminum faces, with reflected lighting.
The back-lit styles are brighter, just like your instrumant panels.
Old Mar 2, 2006 | 03:25 PM
Big Smoky's Avatar
My brother got some LED's from autozone and he says they work great and bright
Old Mar 2, 2006 | 03:28 PM
Mark Craig's Avatar
HOdiesel80,
The new DiPricol's all have the LED lighting that has eliminated this issue 100%. We have been selling their products since 1997 and lots of our customers have gotten the LED replacements from off of the internet that really brighten the old style DI's up a lot. You might try that.
Mark @ DPPI
Old Mar 2, 2006 | 05:18 PM
fox128's Avatar
Which dipricols did ya get? I just put in the Optix series and they are bright and look great!
DieselBoy20
Jul 16, 2008 05:25 PM
ro9beam2002
Mar 11, 2008 10:45 PM
CarlJensen
Mar 31, 2005 04:56 PM
slayerfish
May 11, 2003 09:47 PM
MARKY MARK
Mar 3, 2003 10:44 AM
