Difference between cat back and turbo back...
The tube from the airbox to the turbo. I did mine with only a flathead screwdriver.
Higher sublevel numbers will give you more smoke.
Good to hear you will be responsible with the smoke
Many aren't and are quite proud of that fact. Smoking out pedestrians no matter how deserving they might be just aint good for our image!
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
And a nutdriver means going to get a nutdriver for me. I keep a screwdriver in the door pocket
well thats kinda what it is... a band clamp, screw clamp.. what ever. i've always call 'em band clamps. but you're right, i should have used screw in there also...........
It's a big difference. You'll hear it through the air cleaner and from under the hood. Of course if you have a stock air cleaner, not as much as if it was an afe or k&n or aem or ????????
what would be the difference between getting the afe stage I kit and the torque tube separately and buying a stage II kit with it all together? cuz the torque tube is only $90 from pure diesel power and the stage I kit is $267. buying it separate saves you like 80 bucks.
also, is the pro-Guard 7 filter worth the extra coin?
:edit:
yeah i just noticed that the stage 2 kit has the full box around the filter instead of a heat shield. i'm sure thats the reason for the difference in price.
:edit:
