Delivery Valves Explained?
Old Jan 15, 2008 | 04:46 AM
Txwelder's Avatar
Looking at this picture, I cant see the exact difference between the DV's. Im looking at the full cut, is the shoulder just completely machined off the main shaft or are the four grooves cut longer and deeper into the saft as well?
Old Jan 16, 2008 | 01:19 PM
MikeR's Avatar
Lazercuts and Fullcuts,
The shoulder is just machined off, that's all.
Old Jan 16, 2008 | 01:35 PM
Txwelder's Avatar
So if I removed my DV's, put them in the lathe and turn the shoulder down all the way to the diameter of the main shaft, they would be exactly the same as a set of full cut DV's? Nothing else required here? I am assuming I would notice a large increase in EGT with this modification. Why do the .022's have a pointed tip where the 131's look short and stubby?
Old Jan 17, 2008 | 10:47 AM
thewished's Avatar
Bump
I'm curious too
Old Jan 17, 2008 | 12:00 PM
schoust's Avatar
This has been attempted before if your not right on the money you will have big problems......
Old Jan 17, 2008 | 12:10 PM
thewished's Avatar
schoust where did you get your 022 dv's and how do those comare to 191's or full cuts as far as fuel?
Lil Red
Jun 12, 2003 04:38 PM
dodgeman01
Mar 13, 2003 05:30 PM
yrusoslow2
Feb 19, 2003 09:24 AM
1ST GEN.
Nov 25, 2002 10:26 PM
