Delivery Valves
Old May 7, 2005 | 01:20 PM
12vordie's Avatar
Delivery Valves
I have a '97 3500 dually 5-spd with a 215hp pump. I want to install larger injectors, and was wanting to know are the dv's on this pump big enough to run 370 inj. Will the setup I have in my sig below perform well with the 370's. I know I do need to bump up my timing, if needed I do have #0 plate on the shelf I could install. Any input would be very helpful.
Old May 7, 2005 | 03:13 PM
Forrest Nearing's Avatar
you don't need DV's, your 181's will work perfect
Old May 8, 2005 | 05:24 PM
Rhino's Avatar
I agree with Forrest.
Old May 8, 2005 | 05:41 PM
T_to_the_O_B's Avatar
hello i'm new and i have a problem with my dodge, it's a 93 3/4 ton 5.9 12 valve 4x4, it'll die when it gets up to temp, and then it won't start. it only dies at an idle in gear ( it's an auto). and it'll run fine if your on the throtle all day but when you stop it's over, it wont start. what can i do?
Old May 11, 2005 | 06:03 PM
cumminsdriver635's Avatar
Hey T to the OB I cant personally help you, as i dont know enough about the 1st generations like you have; but post a new topic asking for help and you may get some answers since people will notice it then.
Eric
Old May 11, 2005 | 11:11 PM
12vordie's Avatar
Thanks for the replies guys.l
Old May 12, 2005 | 09:57 PM
bmoeller's Avatar
My guess would be the shut-down solenoid. I know the ones on the 3208 Cat engines will do that when they get warm enough.
Lil Red
Jun 12, 2003 04:38 PM
dodgeman01
Mar 13, 2003 05:30 PM
yrusoslow2
Feb 19, 2003 09:24 AM
1ST GEN.
Nov 25, 2002 10:26 PM
