Delivery valves
Old May 25, 2008 | 01:38 PM
JohnX's Avatar
Delivery valves
It was suggested to me to stay away from 191's because I will be towing and they tend to increase heat...Looking at these DV's and they seem to be the best of both worlds??? Any thoughts on them instead of the 181's ?
http://www.pdrdiesel.com/products/Cu...es-889-35.html
Old May 25, 2008 | 04:57 PM
JohnX's Avatar
Old May 25, 2008 | 10:36 PM
kas83's Avatar
I'm going to be getting a set of those from PDR after my motor is redone and I get some bigger sticks along with a larger charger than my B-1 now.
The 181's in my 97 did fine, made in excess of 400 rwhp with some DDP 2's. With those sticks, it towed well, ran about 1200*, but the B-1 is on the smallish side for my setup. I'm only upgrading to keep up with the new charger.
Old May 26, 2008 | 11:16 AM
JohnX's Avatar
How soon are you switching....I'd really like to find a set of used 181's
Old May 26, 2008 | 05:11 PM
97DodgeRam's Avatar
You have 181's in a 180 pump, which you have. You won't see any change if you put another set of 181's in your truck.
Old May 26, 2008 | 10:55 PM
JohnX's Avatar
My truck is CA emissions with 131 dv's from what I have been told. I will double check them when I change them.
Does anyone know any other way to tell? Like the engine tag maybe?
Old May 27, 2008 | 04:08 PM
Tate's Avatar
If you get the S/N or even the P/N off the pump and call an injection shop, they should tell you. Probably less work to just pull a DV out though.
Old May 27, 2008 | 11:28 PM
JohnX's Avatar
Are they stamped directly on the valve?
Old May 27, 2008 | 11:58 PM
Dodge359's Avatar
Yes, on top.
Lil Red
Jun 12, 2003 04:38 PM
dodgeman01
Mar 13, 2003 05:30 PM
yrusoslow2
Feb 19, 2003 09:24 AM
1ST GEN.
Nov 25, 2002 10:26 PM
