delivery valves?
Old Sep 24, 2007 | 12:07 AM
Mr_Cox's Avatar
delivery valves?
Sorry if this is a newb question because it is, but what exactly are these delivery valves, it seems to me that they are just a part of the injector and people just suggest getting the 300 or 370 injectors instead. Is it kind of like filling the stock injectors with new guts, those being laser cut??
Thanks in advance, as I am reading as much as I can to learn about all this cheap tuning, since I will soon own a 2nd gen 12v 5 speed.
-Ben
Old Sep 24, 2007 | 05:39 AM
schoust's Avatar
D- valves
Hey Ben the delivery valves in a 12 valve are mounted at the outlet of the injecter pump before each line they are there to supply a volume of fuel to each injecter as needed and can be a source of more power!
Old Sep 24, 2007 | 10:54 AM
Mr_Cox's Avatar
So where can I get these DV's? I cant seem to find them online.
Old Sep 24, 2007 | 11:14 AM
97' CTD's Avatar
Garret at www.puredieselpower.com carries them.
Brandon
Old Sep 24, 2007 | 11:52 AM
Mcmopar's Avatar
Call Scheid
Old Sep 24, 2007 | 03:24 PM
Box5's Avatar
Depends what year truck ur getting, if it's a 96-98 you don't really need to upgrade the dv's for power, u can get plenty other ways and stay cooler.
Old Sep 24, 2007 | 03:35 PM
Dodge359's Avatar
I have a set of 191s that I think I am going to take out and go back to 181s. The 191s are making way too much heat with my twins. They did add a little hp according the "seat of my pants" meter but the heat aint worth it.
Old Sep 24, 2007 | 05:46 PM
schoust's Avatar
Get the 191's I looked for a long time and could not find any used,you will be pleased with the punch they add! That is if you don't mind a little smoke!!
Old Sep 24, 2007 | 08:20 PM
TxDiesel007's Avatar
i have some used...
not for sale tho, and u can get them from bosch direct.. they have a pn.. lemme dig it up...
Rick
Old Sep 27, 2007 | 12:54 AM
fluty118's Avatar
i have a 98 12v, as soon as i get a clutch i was planning on getting #10 fuel plate, 3k srings, and dv's but you say i could stay cooler going a different route. what would you suggest.
Old Sep 27, 2007 | 11:48 AM
Mcmopar's Avatar
I dropped a set Scheid DV's in my pump---WOW, awsome increase in power!!!
Old Sep 27, 2007 | 12:06 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I was told yesterday,that companies take stock delivery values and cut them to laser cuts.They cut some sort of shoulder off.Could someone tell me where the pics are on DTR?I'm looking on a set because my rebuilt pump is not fueling at all.
Old Sep 27, 2007 | 07:45 PM
displacedtexan's Avatar
Here you go, they do cut down stock DVs...
Old Sep 27, 2007 | 08:01 PM
dodgeman01's Avatar
I love my DV's They made me 100 more dyno proven HP over stock on my 94.
If I would have known better I would have bought them sooner. Unless you tow a bunch I would not worrie about running a set of dv's
DM01
Old Sep 27, 2007 | 10:50 PM
Dodge359's Avatar
Whats the difference between a 191 and an 022?
I'm guessing its the taper cut on the bottom of the valve?
