Cummins ebrake question
Old Jun 23, 2012 | 08:46 AM
GCSS's Avatar
Hi,
just purchased a cummins engine...a 1995.
it came with a cummins ebrake (by Jacobs)
the actuator is on the exhaust elbow,and the microswitch is on the throttle
plate.... what else am I missing? there is a nipple on the vacuum canister on the ebrake...where does this go?
Thanks!
Old Jun 23, 2012 | 03:11 PM
KATOOM's Avatar
Your exhaust brake should be vacuum activated ON and spring pressure OFF. You may have to call Jacobs to see what parts you dont have but I think you're supposed to have a vacuum solenoid which ties into the main vacuum line and goes to the exhaust brake vacuum pod. The micro-switch tells the solenoid to close (shutting the exhaust brake OFF) when throttle is applied, and open (turning the exhaust brake ON) when there is no throttle. Making sure that setting is right is important since you DO NOT want the exhaust brake to come on while you're on the throttle otherwise EGT's will quickly climb to dangerous levels.
Old Jun 23, 2012 | 04:11 PM
GCSS's Avatar
I had one on one of my previous trucks, but forgot what it all entails...
I'm thinking I should be operational for not too much more money.
Thanks!
I'll call Jacobs Monday.....
Old Jun 26, 2012 | 09:39 PM
GCSS's Avatar
ebrake solenoid
will this work???
http://www.ebay.com/itm/NEW-MAC-PNEU...item1e6f728310
Old Jun 27, 2012 | 01:02 AM
KATOOM's Avatar
It looks right but I couldn't say for sure. Why dont you call Jacobs and get the part? Then you're not guessing.
Old Jun 27, 2012 | 08:16 AM
GCSS's Avatar
Jacobs brake
looks like they would make a great company to have on "Undercover Boss"
I sent then an email,and called them twice. no answer no nothing.
screw them. Ill make something or buy from their competition.
Old Jun 27, 2012 | 08:57 AM
mrclean's Avatar
If you want, I'll post up the part number for the Pacbrake part......
Old Jun 27, 2012 | 09:06 AM
GCSS's Avatar
Please do!!
Thanks!
one more Q... will a push/pull switch be OK on the shifter>?
I noticed on the throttle microswitch there is 3 (three) wires.... how/where to wire this?
Old Jun 27, 2012 | 09:08 AM
nkennedy's Avatar
I would get a solenoid for the vacuum, and control it with a push pull switch on the shifter.
Old Jun 27, 2012 | 09:10 AM
GCSS's Avatar
Did you see the one I found on ebay??
will it work??
also at what point is best to tap into a vacum source??
Old Jun 27, 2012 | 09:42 AM
infidel's Avatar
These instructions are for a PacBrake but it's about the same as Jacobs. Should give you a good idea about missing parts and where they go.
http://pacbrake.com/PDF/L2014.PDF
Old Jun 27, 2012 | 10:29 AM
GCSS's Avatar
OK...from your diagram, it looks as if the solenoid I found on ebay will work.
it's basically nothing more than a switched vacum attatchment.
Thanks!
Sevir
Jul 4, 2007 07:52 AM
guyssets
May 30, 2006 03:55 PM
ratsun
Dec 27, 2005 11:53 AM
kcbarnes
18
Mar 7, 2005 10:16 AM
rock
Dec 4, 2004 01:57 AM
