Copy of my dyno chart
Old Nov 17, 2006 | 12:37 AM
1qckdodge's Avatar
Interesting how it makes more power down low on a lower setting, the 485 run was done on level 5 and the 496 was on 7.
Old Nov 17, 2006 | 12:40 AM
1-5-3-6-2-4's Avatar
very nice...........
Old Nov 17, 2006 | 12:47 AM
1qckdodge's Avatar
Thank you, now its time for some studs, my Mach5s installed, and a head gasket
Old Nov 17, 2006 | 07:13 AM
99blackrig's Avatar
I wished mine looked like that. What kind of dyno was that and how did you make the runs? Did you make them in third gear or od? I dynoed the other day on a mustang dyno and did not get those long curves starting at such a low rpm. I hit all of my power at 2000 rpms and it went downhill after that.
Old Nov 17, 2006 | 07:33 AM
1qckdodge's Avatar
We all dynoed in 4th, we let the converter lock up then rolled into to it at about 50 mph, Im not sure what kind of dyno, NOSPIN, and CTD2001 used this same dyno also, it was at DEZ Racing in Ma.
Old Nov 17, 2006 | 12:01 PM
RowJ's Avatar
It's a Dynojet dynomometer! (written on the chart). Also, they always test in 4th (OD) on auto's. Fairly standard for CTD's.... Peak HP around 2400 rpm, peak TQ @ 2700 rpm.
Mustang Dynos are loaded dynos and test in third, with OD locked out.... reving to 3000+ RPM!
Nice readout!
RJ
Old Nov 17, 2006 | 12:17 PM
1qckdodge's Avatar
Thanks RJ
Old Nov 17, 2006 | 12:51 PM
wcbcruzer's Avatar
Nice numbers. Was all of that on a stock turbo?
Old Nov 17, 2006 | 01:55 PM
haloman's Avatar
His sig says he is running an II62/12
Good numbers. With just another goodie or too you should be into 500s no prob
Old Nov 17, 2006 | 03:53 PM
storx's Avatar
that is a really nice dyno.. when i had my dyno it wasnt as nice of a incline like yours mine more less started at like 80% of my max hp/tq and then kind moved up and down some before spiking for max torque then dropping off near redline...
Old Nov 17, 2006 | 04:32 PM
wcbcruzer's Avatar
whoops... where's the intoxicated emoticon?
Old Nov 17, 2006 | 10:06 PM
1qckdodge's Avatar
Thanks guys, I think I might be able to hit 500 now, I was only seeing 40-42 psi and it only got to around 1100 for temps, maybe she has more left on level 8, tried 9 but it was too touchy, all in all im very happy and will be doing Mach 5s and a upgrade by II.
Old Nov 18, 2006 | 12:34 AM
Ph4tty's Avatar
What was correction factor? It'll usually have a sae # on the bottom of the page
What upgrade from II?
Old Nov 18, 2006 | 12:18 PM
RowJ's Avatar
Originally Posted by storx
mine more less started at like 80% of my max hp/tq and then kind moved up and down some before spiking ...
Love those TST HP curves! They all climb to peak and than give you a 'table top' kind of graph. Edge Comp graphs seem to bounce around more .... and tail off.
Don't know if it means anything significant, one way or the other? It's just a difference I have observed!
RJ
Old Nov 18, 2006 | 04:43 PM
1qckdodge's Avatar
I dont know what the correction factor was, however im gonna send it back to get upgraded to a 64, Im gonna wait to see how hot she gets with the 5s.
