confusion on Fuel press. guage.
Old Nov 4, 2003 | 02:55 PM
Palmetto_kid's Avatar
I am confused. i have been reading about Fuel Pressure gauges, and I understand that the '01 doesnt have a hookup like the 98-00 do. is there something somewhere that describes the intall process, or can someone enlighten me?
thanks.
Old Nov 4, 2003 | 03:08 PM
hellotbone's Avatar
Re:confusion on Fuel press. guage.
Tapped banjo on the bottom of the filter cannister.
Old Nov 4, 2003 | 03:10 PM
BigBlue's Avatar
Look on your injection pump. There is a schrader valve. The way you hook up a FP gauge to this is you need to buy a tapped banjo that will accept the port for the FP sender. They are only like $5 from Wildcat or Geno's. You unscrew the schrader valve and screw the tapped banjo in it's place. Screw the sender on to the banjo. And voila. Your done.
Old Nov 4, 2003 | 03:32 PM
ok blue, i understand that. then why does Geno's sell a Fuel Pressure kid with like 4 banjo bolts?
Old Nov 4, 2003 | 04:41 PM
barracuda's Avatar
probably because you should upgrade all the banjo's at the same time to the larger ones instead of just the one..the kit probably contains all the needed banjo's.
Old Nov 5, 2003 | 12:19 AM
BigBlue's Avatar
It does replcae all the banjos with higher flow models. It upped my pressures overall by 1-2 psi. It was well worth the money. Make sure you get the replacement washers with the kit as well.
XChris1632X
Feb 24, 2008 12:43 PM
Shanajustin
0
Feb 14, 2008 08:42 PM
stock600
21
Jan 31, 2008 12:03 PM
j
May 16, 2007 08:11 PM
Evildiesel
Jun 30, 2005 04:27 PM
