comp box or injectors
Old Jan 31, 2008 | 02:35 PM
joeybaker82's Avatar
my truck has alot of miles and the original IP I have a FASS fuel pump and an EZ. Should I put injectors to get more power or go ahead and get the comp. I worried about tapping into the IP since its old. My injectors are stock as well. Both have never been changed.
Old Jan 31, 2008 | 03:28 PM
01smoker's Avatar
I would put in some mach 4 injectors. That would give you a much greater power gain. That will make a night and day difference.
Old Jan 31, 2008 | 04:54 PM
Ph4tty's Avatar
Wow ain't ya proud of that 436?
All jokes aside I'd look for some small injectors. You might even see a bump in mileage =P Plan on putting some of your tax return into the tranny if you want more.
Old Jan 31, 2008 | 04:57 PM
HOHN's Avatar
You'd think that sigs would not need to be so ostentatious...
Mach 2s are a great injector for all around power and MPG.
M4s are great too-- lotsa power, but not as clean and not as versatile (towing).
JMO
Old Jan 31, 2008 | 05:04 PM
Diesel-Dan's Avatar
Been running just Mach 2's only for the last few years with a big ole smile on my face ....one of these days i will get some more power under my foot (Now that i got my OFE).....im just not rushing it....
I wouldnt go 4's unless you had a bigger turbo......
Old Jan 31, 2008 | 05:10 PM
PaulDaisy's Avatar
So Mach 1.6 or 2? Hohn, Dan?... Or no real difference?
Then of course nobody runs 3 since 4 is so close... still trying to decide.
Old Jan 31, 2008 | 05:17 PM
fordkiller43's Avatar
Shoot just run em both
Old Jan 31, 2008 | 05:19 PM
J Lent's Avatar
What do you do with the truck? Daily Driver? Pull trailers?
Old Jan 31, 2008 | 05:31 PM
HOHN's Avatar
If you're over the age of 60 and/or tow more than 20K, I'd get the 1.6s.
Otherwise, get the 2s
Or the 4s..
I've been running the 4s with a stock charger for a year and a half-- no problems.
Old Jan 31, 2008 | 06:38 PM
Dieselcamper's Avatar
I tow a 7500# camping trailer sometimes to 7000' would
I have any EGT problems with Mach 2 injectors. Also hows
the smoke ? It gets to 105 degrees here in the summer and
I remember when I first installed my Smarty I could hardly
take off from a stop with out blacking out the intersection.
It's alot better now with a little practice
Old Jan 31, 2008 | 07:47 PM
MrTwister's Avatar
my old setup included: Stock Turbo with the wastegate held shut, Comp, Mach 1's, and Snow Stage 2. 1500 degrees empty no problem. Hook the 5th wheel of gooseneck up and comp would be off or on level 1 to keep egt's in check. I would start with a comp. More adjustability, you don't have to tap the wire until you want to.
Old Jan 31, 2008 | 09:03 PM
kennyblatz's Avatar
i have the same set up and put in some bd 130's or 155's were not sure anyway there alittle to much for the stock turbo, egts are in check but i leave a fairly large cloud here and there and it's below freezing but i think a clean set of 80-100's would be good. i went with sticks to save the vp it's going on 310km's now
i dont trailer anything. just a daily driver
Old Jan 31, 2008 | 09:12 PM
J Lent's Avatar
Are you looking to get on a dyno & post big numbers? Do you want no smoke or little as possible? Do you want to race the truck? Just trying to gather some info before advice.
Old Jan 31, 2008 | 09:25 PM
PaulDaisy's Avatar
Or the 4s..
Now that's helpful I do plan to tow 9k# TT monthly.
I love this site. Of course nobody but me can make up my mind. It is very silly to ask questions like that. But it is fun to share and get all kinds of advice!
