Cometics head gasket ?
Old Jan 9, 2008 | 06:29 PM
schoust's Avatar
Hey Phil are you running studs? I think I will be heading towards Orings in the spring that is unless they can straighten these gaskets out or figure out just what the problem is? Phil is that gasket the same as the Cometic mls??
Old Jan 9, 2008 | 10:21 PM
kawi600's Avatar
14mm studs a requirement? must be due to the clamping force needed for the gasket. Wonder what those 14mm's get torqued to and what kind of distortion that causes in the head and block if any. Sounds like a lot of torque.
Old Jan 9, 2008 | 10:36 PM
Mcmopar's Avatar
Yes, I'm using the 12mm scheid studs and their MLS type gasket.
Old Jan 9, 2008 | 10:37 PM
joshua smith's Avatar
ive decided to just run the truck to see how this thing is going to work. test dummy i guess. Ive been running it pretty hard so far with no problems yet. the shop didnt do any machine work as far as the block goes. cleaned the block and head up REAL good, copper spray, and we put it back together.
Old Jan 10, 2008 | 08:15 AM
ratsun's Avatar
Originally Posted by mhuggler
The sales rep. from Cometic unofficially said you need to surface both the block and head for the mls to work, even if the block meets Cummins' specs. The metal gasket just isn't forgiving when it comes to imperfections.
Was done
Did not like 65-70 psi
I don't believe it will be a substitution for o-rings
Old Jan 10, 2008 | 12:45 PM
MoreSmoke's Avatar
kawi600, have you been happy with mass diesel? I am about 2 hours away from you. I was thinking about sending my head out to him for o-ringing. My twins will be here in about a month.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
