Clutches?
Old Jul 7, 2007 | 10:25 PM
  #76
Big Blue24's Avatar
I read an article in Diesel Power that said a bone stock 07' Dmax will run 15.197 corrected. I'll bet that I can't beat that time.
Old Jul 7, 2007 | 11:35 PM
  #77
BBA's Avatar
BBA
That aint a lie either! i seen one of my good friends get stomped by one it had like a 65hp box on it i think. But my buddys truck is a 06 durmax with the banks 6 gun.
Old Jul 8, 2007 | 12:53 AM
  #78
Big Blue24's Avatar
Give me a good turbo and I'll beat every stock vehicle to roll off a production line.... if it's a lambo or an exotic I might have to run it over first but I could at least beat stock trucks with some more air.
Old Jul 8, 2007 | 11:24 AM
  #79
B18B1LS1's Avatar
Originally Posted by 74dart
I also got beat by a 7.3 PowerStroke with a Bully Dog box set on 6. How much power is that in around a 2000 year model ford.
250-280 rwhp on a good day
Old Jul 9, 2007 | 03:18 PM
  #80
BBA's Avatar
BBA
Ok i might have found a great deal on a southbend con-fe. Will the clutch still be the same if it was for a 04 6sd? If so i will more than likely buy it.
Old Jul 9, 2007 | 03:22 PM
  #81
03qclb5spd's Avatar
Hmm, that's a good question. I would think they would be the same but perhaps they are not.
Old Jul 9, 2007 | 03:23 PM
  #82
getblown5.9's Avatar
Whatever it is you smoke, please pass it my way. If its so easy then just buy a turbo so we can see your 600+ hp dyno sheets and sub 11 second time slips.
Old Jul 9, 2007 | 03:24 PM
  #83
BBA's Avatar
BBA
yea but im pretty sure that the reverse is in the same place?
Old Jul 9, 2007 | 03:43 PM
  #84
i cant be sure but if it was for a 5600 in the 04, then it should be the same for your truck.
call peter he will tell you
Old Jul 9, 2007 | 04:18 PM
  #85
BBA's Avatar
BBA
If the reverse is in the same place shouldnt it be the same though?
Old Jul 9, 2007 | 04:51 PM
  #86
if R is the same then yes
Old Jul 9, 2007 | 05:04 PM
  #87
74dart's Avatar
The 5600 and 4500 has the same shift patters but the Mercedes 6 speed is what I think is called a reverse rotation but reverse is beside the 1st gear and not the 5th like the 5600. I have not confirmed this that is what the parts man at my local dealer told me last friday.
Old Jul 9, 2007 | 05:12 PM
  #88
BBA's Avatar
BBA
Well i called south bend earlier and im not sure hwo i talked to but he said it would be the same. Now this clutch doesnt come with a flywheel am i going to need to get another flywheel?
Old Jul 9, 2007 | 05:54 PM
  #89
Muddin_dude06's Avatar
It shouldn't need a flywheel, but if it doesn't work out PM me and I'll give you the number to ValAir. I stand by their clutch because it has worked out really well for me, and Dan is really good to deal with.
Old Jul 9, 2007 | 07:54 PM
  #90
HOHN's Avatar
GB5.9, I like you more with every post you make!!
