clutch not working?
Old Apr 14, 2008 | 08:16 PM
kyle_truck_pull's Avatar
Exclamation clutch not working?
a friend of mine has a 12 valve, it has some pump work and delivery valves. it runs pretty good, turns about 4800 rpms. anyways we had put a new clutch in it 200 miles ago and he did a big burnout, he grabbed 4th gear and it started slipping. after he let of he had a dead peddle like the slave cylinder quit working. he put a new slave cylinder in it, and the peddle feels like it is there but still wont go into any gear? what could of happened? and why wont it work? also the clutch is a bigger single disk south bend clutch. thanks for any input, he could use the help.
Old Apr 14, 2008 | 09:12 PM
Common's Avatar
4800, huh?
Old Apr 15, 2008 | 03:37 AM
rpms are cranked up
Old Apr 15, 2008 | 07:05 AM
blackdiesel's Avatar
Registered
The disc face probably came apart and is stacked between the pressure plate and the flywheel.
Old Apr 15, 2008 | 03:30 PM
that doesnt sound good, can that happen even with a new clutch? he was pretty hard on it grabbin gears and stuff.
Old Apr 15, 2008 | 04:58 PM
Registered
and a "big burnout" with a new single disk clutch under 200 miles is pretty retarted.
Yes, it can happen. Same thing happened to dad, but he was just downshifting to turn off onto our road. It wasnt a new southbend, but it could happen to any of them.
Old Apr 15, 2008 | 07:31 PM
thanks, i will let him know that hes retarded. whats the best way to break in a new clutch? or is there. he plans on pulling it this season too.
Old Apr 15, 2008 | 08:09 PM
Registered
Southbend usually recommends (dunno what size he got) 500 miles of easy driving and some stop and go (ex. in town driving)
If he wants to be in the pulls, he should have went double disk. heh, he may get that chance.
Old Apr 16, 2008 | 08:16 PM
he has 1800 in this clutch, for a few more hundred he could of had the double. lol
Old Apr 17, 2008 | 12:19 AM
blueboy16's Avatar
just my .02 cents but i had this same problem with mine and it was that the clutch fork got bent i have no idea how but it did. dodge dealer said they have never had anything like this happen before so i dunno
Old Apr 17, 2008 | 05:18 AM
jjb3006's Avatar
Just out of curiosity, did you have that installed for 1800 or did you just buy a single disk for 1800, cause if that is the case then I would say that you got the short end of the stick.
Old Apr 17, 2008 | 06:40 PM
Registered
my double disk cost me 1800 dollars and i installed it myself. i was thinking the same as jjb. If he only got a single disk for 1800 he got shafted
Old Apr 17, 2008 | 08:42 PM
he got the big imput shaft, a new fly wheel and clutch for 1800.
Old Apr 19, 2008 | 04:04 PM
Registered
So he did get the shaft. (the input shaft that is)
Old Apr 20, 2008 | 04:30 PM
ya he got the shaft too.
Sleigher
May 4, 2017 02:12 PM
sluketic
May 30, 2008 01:03 PM
dieseldel
Sep 19, 2007 12:46 AM
03dodgeoffroad1
Jul 24, 2007 01:48 PM
