Clutch is going...
Old Jul 31, 2007 | 03:47 PM
xOmertAx's Avatar
Clutch is going...
My clutch is going out. What would yall recommend? I don't really want to spend the money for a southbend. Would the Luk Pro Gold be a decent option?
Old Jul 31, 2007 | 04:48 PM
dodgezilla04's Avatar
south bend. i know you dont want to spend the money. but why do it twice?
Old Jul 31, 2007 | 04:49 PM
xOmertAx's Avatar
bacause i'm a poor highschool student? haha thanks...i'll take it into consideration
Old Jul 31, 2007 | 04:51 PM
TxDiesel007's Avatar
Valair inc
mine has held over 500 horse power and no sweat.... Dan makes a heck of a clutch...
Rick
Old Jul 31, 2007 | 04:56 PM
mysterync's Avatar
I've ran many type of clutches, In all honesty you would be better going southbend, but if you cant over come money issues stick one in and be easy on it till you get saved up!
Old Jul 31, 2007 | 05:08 PM
stuckey200224's Avatar
i will go aginst what every one on here will say and tell you to stay away from south bend there are lots of 2 disk clutcher out there that are way better that sbc and nost are the same price if not less
Old Jul 31, 2007 | 06:16 PM
xOmertAx's Avatar
where can i get one?
Old Jul 31, 2007 | 06:23 PM
try haisleys web site (haisleymachine.com) or you can go were i got mine (powerpartsengineering.com) ask for terry he will help you out the price is about the same as sbc maby a little less but it is a way better clutch (at least so far)
Old Jul 31, 2007 | 07:22 PM
66fordcrewcab's Avatar
haisly clutches are junk. The luk clutch would be a good clutch. I had one in my truck and it was holding my Smarty on 9 and TST 9 run ok till i did a couple of 3rd gear launchs and it went south from there. If you drive it right it will hold good pull. You don't always need a DD unless you want to sled pull with your truck then it helps.
Old Jul 31, 2007 | 08:16 PM
xOmertAx's Avatar
i might sled pull 2x a year IF that
Old Jul 31, 2007 | 08:20 PM
blackdiesel's Avatar
Registered
if you sled pull you're lookin at a double disk. which is almost double. So is it worth it? thats up to you
Muddin_dude06's Avatar
I'm with Rick here get a ValAir, it is the best clutch for the money without a doubt! Mine holds 400-425HP everyday (when the truck isn't tore down ) and has great drivability. Dan is also awesome to talk to on the phone when ordering or to answer any questions, I will buy a clutch from ValAir only now...
Old Jul 31, 2007 | 08:23 PM
xOmertAx's Avatar
the thing is, if i tear up a 375 dollar luk clutch, i wont feel half as bad as if i did that to a southbend. and i know for pulling you need a double disk, but if you are going to do it once or twice, the clutch should stand it
Old Jul 31, 2007 | 09:39 PM
Big Blue24's Avatar
Are you intalling the clutch yourself? If not then I would buy a good one. Labor will run you almost 500 bucks per install. 500x2 = 1/2 of a double disk or two good Feramic Valair clutches.
If I were you, I would get a valair clutch, it will hold more than a luk gold. I burned up my luk gold with just my Juice. I then got the standard facing organic 13" upgrade rated at 300 HP and it did not slip till I added my RV 275's on top of my HOT Juice. Dan recommended just a standard 13" upgrade but then 3K miles later, felt bad that his clutch would not hold RV 275's + HOT Juice on 315 Buckshot mudders; so he sent me a full feramic clutch free of charge. This FE clutch will not slip period. Since then I have added my Jammer 5's and still, even with boosted 2nd gear starts on the pavement, this clutch will not slip. Now I do not slip the clutch for 100 feet when I take off with boost, I just dump it and let the tires take a beating, so no, it is not like a double disk, but for 600 bucks, how can you go wrong.
All that said, if you are doing the labor and you are strapped for cash, sure get a Luk clutch and then in a year, when you have 600 saved up, buy a Valair FE 13" upgrade. 13" flywheel from an HO machined to accept 1.25" input of a 5 spd.
Old Jul 31, 2007 | 09:42 PM
03qclb5spd's Avatar
Good luck getting the luk to last.......might not even get off the line before you trash it.
