Chips
Old Jan 25, 2007 | 03:52 PM
WARFootball77's Avatar
Smarty or edge
What is the difference between a smarty and an edge/att.
Old Jan 25, 2007 | 04:40 PM
Big Smoky's Avatar
A Smarty is a plug in programmer that plugs into your OBD2 port under the dash. It's an excellent product. It helps mostly on the low end and you can also run it with or without timing. The Edge Juice w/Attitude is a fueling box and it includes timing as well. The Attitude is actually the display monitor that has all your gauges on one screen. You can stack the two and run the Smarty without timing and you will have an awesome setup! You'll need a turbo after that! Good luck and I hope this helps.
Eric
wick
13
Mar 18, 2003 07:57 AM
zeik
Mar 17, 2003 07:33 PM
Buzz
Feb 4, 2003 08:49 PM
bigbaddiesel
Nov 23, 2002 02:32 PM
ox
Nov 21, 2002 07:47 PM
