check timing 12v
Old May 28, 2009 | 10:02 PM
sway825's Avatar
check timing 12v
how do you check timing in 12v
Old May 29, 2009 | 12:00 AM
Fueling around's Avatar
The most accurate is flow timing. It uses a timing light to strobe the mark on the balancer and a flow sensor clipped on the #1 injector line.
Old May 29, 2009 | 12:54 AM
Dr. Evil's Avatar
Where do you get a flow sensor for an injector line?
Old May 29, 2009 | 01:27 AM
I cannot find the link.
A nifty kit has a flow sensor that clips on an injector line and has a timing light that strobes the balancer mark. A digital read out gives you the timing.
The Snap-on or Miller kit is accurate for setting the timing based on plunger lift, but the flow timing is more acurate for dynamic testing.
Old May 29, 2009 | 01:31 AM
Dr. Evil's Avatar
Interesting - I though everyone used the plunger lift method.
Old May 29, 2009 | 02:05 AM
1-5-3-6-2-4's Avatar
I used one of those at SAIT when I was in 2nd or 3rd year. its a diesel pulse adapter wired into pretty much a standard timing light. I don't recall the brand I used at SAIT but pretty sure snap-on or bluepoint has one.
Fueling around.......you realize that the 12v cummins has no timing advance feature whatsoever right? whether VE rotary or P7100. doesn't matter, theres no advance mechanism.
B series are set to operate at static base timing, thats as good as it gets.
Old May 29, 2009 | 03:48 PM
Tate's Avatar
I thought the VE's had a timing advance mechanism in them? The 215 pumps retard timing based on rack travel. Thats why they have the v-notch plungers, while the other pumps are all flat tops.
Old May 29, 2009 | 03:57 PM
Mcmopar's Avatar
How much do they cost?
Old May 29, 2009 | 08:23 PM
Last I looked at the timing set it was around $800
I'm still trying to find the link to the one used on my truck.
I say dynamic as plunger lift is a mechanical estimate of the pump based on an injector pop-off.
BTW, if you measure at the pump versus the injector with the pizeo clip, the delta is around 4° less at the injector.
VE pumps have over 16° of mechanical advance. Some of the Roosa pumps had an advance, too.
The lowly P pump has some funny stuff with the plungers as Tate noted. Actually as the rack travels it will advance the injection slightly. A full plunger pops off the injector a couple degrees sooner than an empty plunger.
Old May 29, 2009 | 11:39 PM
Dr. Evil's Avatar
School is in... - good info.
Old May 30, 2009 | 10:14 AM
how does the VE dynamic advance work? How does it advance BOI with engine speed? What 6B uses a Roosamaster pump? I know some industrial 6Bs use a Nippondenzo, but thats all I've heard of.
I only knew about stanadynes with dynamic timing advance. i used that kit on an International years ago.
Old May 30, 2009 | 11:17 AM
if it doesn't advance beginning of injection, its not a dynamic timing advance. I'm not sure what the purpose of that notch is. maybe increase fill time.
Old May 30, 2009 | 03:51 PM
Tate's Avatar
The purpose was to retard timing for emissions reasons. At full rack travel, you would lose between 4 and 6 degrees.
Old May 30, 2009 | 04:11 PM
I was just comparing the VE to the Stanadyne Roose pump as they are very similar in internal design.
Never seen a Cummins with a roosa. That would be the 6.2/6.5 Chevy; 6.9/7.3 Internationals as well as John Deere.
Old May 30, 2009 | 04:32 PM
I know for sure stanadyne on the 6.2 chevy has it, and I know its a weak design. but does the VE? I'm not convinced.
theres a couple former injection pump specialists at work I'll ask.
